Neutral Light Installation
8 replies to this topic
  • Big Red Paul
Posted January 23, 2007 - 04:27 AM
Would like to install a neutral light on my XR650R. It is sometimes tricky to select neutral when wearing my moto-x boots while riding on the road.
I have the standard speedometer with indicator light, and high beam light(blinkers).
How can I wire up the indicator light, which is green, to light up on my display when in neutral ?
I also have no ignition key. Is it easy to install a key set up ?
Would value any input.
Thanks guys.
  • MindBlower
Posted January 23, 2007 - 07:04 AM
Thanks guys.
There is a guy on ebay that sells Honda ignition keys mounted on a very sano bracket. Easy install. I think he usually sells with speedo but if you write him I bet you could get the bracket/key only.
  • cleonard
Posted January 23, 2007 - 08:19 AM
I think that you are out of luck on the neutral light. Street bikes have a switch inside the engine that is on when the transmission is in neutral. The XR650R does not have this switch, so there is nothing to wire your indicator too.
  • XR650L_Dave
Posted January 23, 2007 - 08:44 AM
Is there a foreign XR650R-based street-legal bike?
That would prob. have a neutral switch, and if so, perhaps all 650Rs are capable of having the switch installed.
Dave
  • rcnutt
Posted January 23, 2007 - 09:34 AM
baja designs has a key set up for 29.99 any shop can order it for you
  • Big Red Paul
Posted January 23, 2007 - 04:55 PM
Thanks for the info guys. Will order baja designs key set from my local shop.
So there is no one out there with a neutral light ? I guess cleonard is right. I doubt if Honda were/are putting neutral switches in there foreign model engines. Short of pulling the engine apart, to check...
I looked through the CD-Rom that came with the bike, and can't see anything.
I guess if I want a neutral, I need to buy a DR650. Thanks, but no thanks.
  • ganshert
Posted January 23, 2007 - 09:58 PM
I looked at the wiring diagram for the Australian model and there is no neutral switch or light. turn signals and brake lights though
  • Big Red Paul
Posted January 23, 2007 - 10:08 PM
Yeah, I have that Auzzie bike. Thanks ganshert, I guess that is definitive.
  • Beelzeboss
Posted January 24, 2007 - 04:52 AM
The European version has no Neutral light switch either.
  • 3 replies
  • 22 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
