SSR forks
10 replies to this topic
  • racert17
Posted 22 January 2007 - 04:02 PM
Can anyone tell me what the inverted forks and brakes are like on a SSR race series bike? How do they compare to other inverted forks and brakes out there on other models..pitster etc
  • ridered55
Posted 22 January 2007 - 09:08 PM
Brakes are good ( although rear draggs a little) Forks have potiential to be very good but, they are way to stiff out of the crate. A re-valve is needed because the clickers dont do much "adjusting" ( due to crappy factory valving) This is acurate information- hope this helps...
  • stlwalnut
Posted 24 January 2007 - 02:49 PM
Changing the fork oil made a world of difference in my ssr forks. 100cc of 10wt in each leg made the clickers actually make a noticable difference. Forks also become way plusher.
  • theyouthahead
Posted 26 January 2007 - 02:51 PM
can you buy the forks that come on the higher end ssr bikes cheap?
  • speedo241
Posted 27 January 2007 - 05:16 AM
:ride: I used 100cc of 15wt oil in mine and there really good.The clickers work now you can tell a difference with quality oil.Great forks at a decient price.
  • speedo241
Posted 27 January 2007 - 05:20 AM
Yes if you look around you can get them cheap.There was a guy on pm that was selling a pair complete cheap.Also keep a eye out on 50 riders I have seen them on there aswell.Good luck
  • DirtBikeDude409
Posted 27 January 2007 - 08:53 AM
yeah I would think that the stock fork oil is junk in the SSR's as well as the ret of them.
  • KINGSPADEFIDDYS
Posted 03 June 2007 - 05:42 PM
You Can Do Any Upgrade You Want To The Staggs Forks That Come On The Ssr / But If You Ride On A Track With Good Jumps, You Will Break The Dampining Rods And The Fork Will Over Extend Any Time The Front Wheel Comes Off Of The Ground. You Will Need To Space The Springs To Pro Long The Forks Life, But They Will Break Again.
  • thejunkman
Posted 03 June 2007 - 07:00 PM
Hmm... I have never had any problems with my SSR inverted forks I have had them almost 2 years. Religious oil changes of 110cc of 7.5wt oil. I have never broken a thing and they do get a work out.
  • trhine3
Posted 09 April 2008 - 12:13 PM
mine leak oil out of the adjustment knob any suggestions on how to fix??
  • chirorider
Posted 09 April 2008 - 01:12 PM
Exactly where do you get this information?? I have Staggs forks on my midsize and I definitely jump it and I am not a little guy. Not to mention that Pitsters came with staggs forks until this year(and the current gpx looks strangely similar) and I have not heard of such failures.
