How to change clutch springs!!!
6 replies to this topic
  • christoswr
Posted January 22, 2007 - 07:00 AM
I have an 03 YZ450F and i bought new clutch springs.
Is it hard to change them by myself?
Posted January 22, 2007 - 09:31 AM
Very simple. Do you have a manual?
http://www.yamahaown...ook.com.au/?r=0
  • Jaycycle
Posted January 22, 2007 - 09:34 AM
No, its almost as easy as putting gas in your bike.
  • Baron Von Beard
Posted January 22, 2007 - 10:12 AM
Lay the bike on it's left side, pull the clutch cover, remove 6 bolts on the pressure plate, pull springs, put in new ones, tighten bolts in a cross pattern, install clutch cover and put bike back on the stand.
  • christoswr
Posted January 22, 2007 - 11:05 AM
:lol:
Thanks
  • Fastest1
Posted January 22, 2007 - 03:28 PM
Why are you only changing the springs? If your clutch is slipping, you will need frictions and maybe even steels then the springs will help.
  • christoswr
Posted January 22, 2007 - 04:57 PM
My clutch is not slipping! I just got some new springs for free so i thought i should check the clutch and if its springs are below the free length limit i will put the new ones.
  • Hot  36 replies
  • 0 replies
  • Hot  50 replies
  • Hot  113 replies
