Engine temp - 50 degrees C ok ?
4 replies to this topic
  • 04WR450man
Posted January 22, 2007 - 03:13 AM
Hi,
I fitted a trail tech vapor at the weekend to my WR426 after everyone recommending them on here, I am very pleased with it but the engine temp only gets to 60 degrees C if idling for a few minutes/riding in tight woods or 50degreesC if riding normally, is this ok, i would have thought it would run hotter than that ? it is only 5-6 degrees here in the UK at the moment so maby in the summer it will run hotter ?
Many thanks
Trev.
  • 04WR450man
Posted January 25, 2007 - 02:37 AM
Any one know if this is ok ? 50 degrees C is about 120 F ???
Thanks
Trev.
  • bluemax250
Posted January 25, 2007 - 11:49 AM
Seems a little low, is the sensor on the coolant as it comes out of the engine or the radiators ?
  • 450high
Posted January 26, 2007 - 01:18 AM
made up my own electronic temperature guage and mounted it to top of right radiator.Runs 40 to 90 c depending on wether its open trail or stuck on a hill.
hope this helps dave.
  • 04WR450man
Posted January 26, 2007 - 03:47 AM
Thanks for your replies :ride:
I mounted it as per instructions, its on the long coolant pipe on the left radiator (if sitting on bike), i thought this was the 'hot' pipe, does anyone know if its supposed to be on the other side?
Thanks :ride:
