Compression Test 2001 XR650
6 replies to this topic
  • ghride
Posted January 21, 2007 - 10:29 PM
Anyone know what a good compression test reading would be for a 2001 650.
Due dilegence on a used bike with well maintained bike with a few hours on it.
I found a site that said a minimum of 100psi. How does the compression ratio 10:1 vs 11:1 translate into fresh psi? Any insight appreciated.
  • johnnyonthegas
Posted January 21, 2007 - 11:03 PM
R or L?....sounds like an R....
  • cleonard
Posted January 22, 2007 - 12:07 AM
The problem is the decompresser. It keeps an exhaust valve open, so you don't see full compression.
  • ghride
Posted January 22, 2007 - 09:34 PM
Its a 650R.
I asked the local Honda dealer and the mechanic said a fresh rebuild would give 86 psi with decompressor engaged and 160 psi with decompressor lever released. So my next query is whats the cutoff pressure to be concerned, 120? 140?
  • cleonard
Posted January 22, 2007 - 11:14 PM
Its a 650R.
I always thought that with the kick starter, you couldn't turn if fast enough to disengage the cam decompression system.
What are you measuring?
  • ghride
Posted January 23, 2007 - 01:24 PM
I havent tested it yet, I'll be test riding the bike and compression testing this weekend.
You may be right, I dont know that much about how the decompression system works, I presumed that if you dont - pull and hold - the decompression lever than you would be kicking against full compression, which is consistent with the 2 different PSI's noted from the honda dealer.
Guess I'll have to check it and find out.
  • ghride
Posted January 23, 2007 - 04:35 PM
cleonard,
do you know for sure if the 01 XR650R has an auto-decompression system that disengages once the rpms get high enough?
After reading a few other related posts, I started learn what you were referring to. The 160 psi the dealer mechanic gave me may be when the auto-decompressor is deactived somehow.
A motion pro leak down tester is a little spendy for my needs right now, I could put new valves in for the cost of one.
