07 YZF 450 Hi/ Lo Compression settings?
4 replies to this topic
  • yamahadrz
Posted January 20, 2007 - 08:36 PM
What is the lo compression and what is the hi compression settings on the shock for? Low speed and Hi speed? I am unsure what they each accomplish.
I have sag set at 3.5" and weigh 175. Where is a good start point to set suspension on both hi/ lo and also rebound?
Thank you-
  • Bigcr
Posted January 20, 2007 - 08:39 PM
Start with what the manual recommends (don't trust the bike from your dealer) for clicker settings with 100mm of sag. I've found that the stock stuff needs the rebound cranked in a bit.
  • Mike McCutcheon
Posted January 20, 2007 - 09:01 PM
Check your owner's manual. It's pretty informative and will explain the difference between high and low speed compression. I've got an 07 450. I set my sag at 100mm and raised the forks 10mm in the clamps but so far the valving seems pretty close. A friend of mine has one also, weighs 178, and did the same to his. These bikes are really good right out of the box.
  • red7
Posted January 20, 2007 - 10:26 PM
Did you first try raising your forks 5mm or did you go right to 10mm? I'm just curious because everyone recommends 5mm and I've been happy with mine there but haven't thought of trying out 10mm.
  • Mike McCutcheon
Posted January 21, 2007 - 01:44 PM
I tried 5mm first and it helped, but since I was coming off of a 2005 RMZ 450 the YZ was still not as quick a turning bike, but alot more stable at speed. Honestly, I'm not sure 5mm more made too much difference. We've had bad weather here so my track time has been limited to try less sag (95mm) like some of the magazines recommend. Sure like this bike though!
  • Hot  50 replies
  • Hot  30 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  47 replies
