Holding flywheel in place?
5 replies to this topic
  • YZ426F Rider
Posted January 20, 2007 - 09:51 AM
Trying to get my flywheel off to replace my timing chain, etc. but I am having trouble holding the flywheel in place to remove the nut. Locking the rear wheel won't work as I have a Rekluse.
I saw in another thread that a guy wedged a piece of wood in front of the counterbalancer to lock everything up but I'm wondering if that is strong enough. I'd hate bust that. I actually have an air impact driver...but my compressor is too small to run it effectively :lol:
Anybody have any tips or tricks?
  • YZ426F Rider
Posted January 20, 2007 - 10:01 AM
Nevermind, just got it off...my cheesey air compressor came through for me! :lol:
  • DPW
Posted January 20, 2007 - 10:31 AM
so how are you going to hold it so you can torque it down?
  • motoag93
Posted January 20, 2007 - 12:38 PM
I had the same issue with the clutch on my kx250. I never did torque down the clutch nut to the proper specs as I could not get the hub still by just using the brake. I ended up tightening it with the impact wrench (rat-i-tat-tat).
The nut only came off once........but not a cool feeling:bonk: . In hindsight, I would have purchased the correct tools for the job and used a torque wrench as recommended.
  • YamaHonda
Posted January 20, 2007 - 01:40 PM
On my CRF, I used the 10mm allen in a socket wrench on the right side of the case. Not sure if the YZF has a similar set-up on the right side of the crank. I had a buddy hold it in place and I could do the job without an impact wrench or a flywheel holder.
  • YZ426F Rider
Posted January 21, 2007 - 09:14 PM
I ended up wedging a piece of hdpe in between the balancer and the case and holding my breath while slowly torqueing the nut down to the 35 ft/lbs spec.
After replacing the piston, rings, timing chain, valve seals and springs she fired up on the second kick :lol:
  • 9 replies
  • Hot  47 replies
  • 10 replies
