06 450 helppppppppppp.
11 replies to this topic
  • matts06yzf
Posted January 17, 2007 - 06:29 PM
ok I was running stock front and rear was 48 Tag, Well I went to 50 t tag rear and My damn chain is to short I am running a o ring rain but for the life of me cant rember which one. So what are my options and should I just get a new chain ? I f I get a new chain what size should i Order? This sucks cause i just spent a 100 bucks on this chain. I just got my suspension back from enzo and want to ride and now this:bonk:
  • flintlock28
Posted January 17, 2007 - 07:16 PM
I know occasionally, people will use two or three master links, to add length. I've hear running two is o.k., but I'm not sure about running three.
  • Drfletcherdc
Posted January 17, 2007 - 07:24 PM
Try a 49 T stock gearing or buy a new chain. Last thing you want is the chain to break becoming a lethal weapon.
Posted January 17, 2007 - 08:57 PM
I've been running two masters on a Regina ORN6 for two years. However, as external widths of chains tend to vary, I don't recommend doing this unless you can get exactly the same brand and model of master link to match the chain you're running. So, in your case, unless your memory gets jogged, either get a new chain, or use your old gearing.
  • Baron Von Beard
Posted January 17, 2007 - 09:05 PM
Uhhh, you are supposed to change both sprockets and chain all at the same time. Shame on you! :lol:
But anyway, you can run another master link as long as you have another inner link. If you don't, you need a new chain.
  • matts06yzf
Posted January 17, 2007 - 09:10 PM
ok what size chain do I need? 13-50 for sprockets Thanks guys
Posted January 17, 2007 - 09:14 PM
Buy a 118 or 120 and cut it to fit.
Posted January 17, 2007 - 09:23 PM
...you are supposed to change both sprockets and chain all at the same time.
Not necessarily. If the original chain was allowed to run over 1.5-2% over the specified length, the sprockets probably are worn to the point where they need to be gone, too, and that's what usually happens. But I've worn out a number of rear sprockets with a chain that was still under 1% stretched. It just depends on the situation.
  • matts06yzf
Posted January 17, 2007 - 09:30 PM
Ill just buy a new chain, Thanks
  • Baron Von Beard
Posted January 17, 2007 - 10:16 PM
I always buy a 120 link chain and cut it to fit so I can make it as short as possible.
  • black_n_blue_thumper
Posted January 17, 2007 - 10:44 PM
I dont know if this will help you or not. But I run aftermarket axle blocks, that you can flip, so I can run different gearing without switching chains. This may work for you. Mine are kind of like these.
http://www.yamaha-mo...0/0/detail.aspx
Posted January 18, 2007 - 08:55 AM
You can do the same thing without the blocks, if the chain is of a length that will fit both sets of gearing. The advantage to the blocks is that you don't have to move the adjuster screw so far when changing over.
  • 10 replies
  • 0 replies
  • Hot  50 replies
