Handguard Woes, Which Ones Are You Running??
33 replies to this topic
  • Boston Mangler
Posted January 18, 2007 - 05:49 AM
#21
OK, i didnt find any "shortys" for the XR650L but i did find a bunch for the XR600. Anyone know if they are the same?
Thanks
  • XRsteve
Posted January 18, 2007 - 10:03 AM
#22
L levers are different. They have to activate the brake lamp and clutch switch. Look at the levers and you'll see what I mean.
  • Research Rat
Posted July 03, 2008 - 07:47 PM
#23
A friend gave me his pair of Acerbis handguards that he originally had on his bmw x challenge.
When it came time to mounting on my xr650l, I found that the "shaft" that goes into the end of the bar was way too large to fit in the end of the bar.
Is there a specific size handguard that fits xr650l bars?
Thanks.
-Scott
  • clintp
Posted July 03, 2008 - 08:07 PM
#24
I had to dremel out the throttle side pretty wide, the other side was just filled with grip glue. There's probably different sized inserts, the ones I just mounted had a rubber sleeve that fit over the inside-the-bar wedge.
I love these things - they do a great job protecting the bars & controls, even if they do twist slightly in a crash. The ones on my CR are way out of wack, but that doesn't seem to matter at all.
  • Research Rat
Posted July 04, 2008 - 06:04 AM
#25
Clintp,
I don't think dremeling is the answer in my situation. The handguard insert is just too wide.
Do you have specific details on insert sizes available?
Do you know the size of the stock xr650l bars? 7/8?
Thanks.
-Scott
  • jbird710
Posted July 04, 2008 - 06:34 AM
#26
There are different mounts depending on the size of bars you have. If you are running stock bars, they are 7/8". Here's a page from the TT store that shows the different ones available:
http://shop.thumpert...fault.asp?p=591
I'm pretty sure you want the outer mounts for steel bars but you may call the TT store to verify.
  • LT1coupe
Posted July 04, 2008 - 07:34 AM
#27
Tusk fit mine well
  • clintp
Posted July 04, 2008 - 08:31 AM
#28
Clintp,
Thanks.
-Scott
Something like the M6002-10 + M6002-11 is likely needed for stock bars.
I was careful not to nick the inside of the bars but I had to open up the throttle tube quite a bit & cut a ton of grip off the outside edge (leave the outside rib, a big razor worked better for me than x-acto). It was the first set I've installed, my other pair came with the other new to me bike. I think jbird put you on the right path.
  • RipperFox
Posted July 04, 2008 - 08:33 AM
#29
Most handguards are made for aluminum handle bars.
Steel have a smaller Inside Diameter. Which stock "L's" are. I had to buy a set of Alum bars to get my Fastways to work.
Fastways are great with the intergrated damper mount.
  • clintp
Posted July 04, 2008 - 08:46 AM
#30
ripperfox - did you happen to notice the weight difference between the steel & aluminum bars?
  • RipperFox
Posted July 04, 2008 - 09:48 AM
#31
Like exactly? NO
but the alum were much lighter. Like half.
  • Research Rat
Posted July 04, 2008 - 12:26 PM
#32
I'm an idiot :thumbsup: Upon closer inspection, it was the throttle end cap that was inhibiting the handguard mount to slide into the end of the bar.
A bit of dremeling on the throttle to open up the hole and the handguard mount slid in just fine.
Aside from the dremeling, the Aceberis guards mounted right up.
-Scott
Clintp,
Thanks.
-Scott
  • Suikerland
Posted July 11, 2008 - 12:48 PM
#33
I use the original Barkbuster guards (from Australia), also had to cut the little balls off the levers.
I guess they are there to prevent the levers digging into you in a crash, and with the handguards thats not going to happen, so dont need them.
Pic here
http://www.thumperta...510#post6653510
  • zipper600
Posted July 11, 2008 - 02:27 PM
#34
Polisport handguards.Were cutted and modified.Added some home made Stainless steel spacers to get some extra room for cables. On the inside of the handle bar i applied some Berner concrete metal bushings to have more solid grip.About 30 euros total cost.
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
  • 22 replies
  • Hot  148 replies
