Will Bent Head Pipe Affect Radiator
4 replies to this topic
  • yami racer
Posted January 16, 2007 - 08:08 AM
Had a slide out and bent my head pipe a little bit on an '06 yz450f. Aside from a little airflow constriction do I need to worry that the heat will affect the bottom of the radiator. It is now about 3/4 of an inch from bottom of radiator.
Plan on sending it out to get repaired but need to use it to race on Saturday and there is not enough time.
Thanks.
Posted January 16, 2007 - 08:50 AM
3/4" is a lot of room compared to most older 450's. It's a non-issue. No worries.
  • altered
Posted January 16, 2007 - 11:55 AM
If you are concerned about it, let it idle for a couple minutes and get red hot, then push down on the header with your boot. It will bend back down. I have done this a couple of times. My header now needs a pro fix but it did bend back.
  • rexbond007
Posted January 16, 2007 - 06:31 PM
better yet use a pry bar and block of wood , u might melt your boot.
  • Troutman
Posted January 16, 2007 - 06:52 PM
You may be able to get a new stock one from a fellow TTer for a good deal. I went that rout and was very happy with it.
  • 0 replies
  • Hot  94 replies
  • 0 reviews
