Chain and Sprockets
13 replies to this topic
  • 30-A rider
Posted January 15, 2007 - 11:58 AM
I have done a search so dont flame me; just didnt get any solid recomendations for my particular needs.
2000 YZ 426. I dont race but do ride an MX track. Dont care so much about weight..most interested in best bang for your buck.
Lets keep it simple with recomendations and explanations, and hopefully there wont be any flaming amongst TTmembers on this thread.
Thanks in advance to all who reply..much appratiated.
Posted January 15, 2007 - 12:07 PM
For the chain, I recommend the Regina ORN6. It's a $65 chain (Regina makes the identical Renthal R1, which sells for around $85) that will last about two years or more if you take care of it.
Sprocket choice is pretty wide open. I'd avoid the cheapest stuff, and probably would not go with the most expensive, either.
Steel rears last the longest, but except for Ironman and one or two others, they are very heavy. Good quality, truly hard anodized aluminum sprockets like the Tag and AFAM rears hold up quite a bit better than heat treaded alloy cogs like Renthal. Your choice.
  • King_Air
Posted January 15, 2007 - 12:27 PM
I second Grays recommend chain and Tag sprockets. I just got the Regina chain and Tag front and rear from right here at the good ol Thumper Talk store. I haven't done any rides with them yet, but I like the looks of them for now.
  • 642MX
Posted January 15, 2007 - 04:44 PM
I use the Primary Drive brand from Rocky Mountain. You can get an O-Ring chain and 2 steel sprockets for $57.99. After a year of use on my 426 I had to adjust the chain once and the sprockets look nearly new.
  • Wiz636
Posted March 27, 2007 - 09:28 AM
I have been running a Regina ORN6 and Sunstar steel sprockets on my 426 for about 8 months now and I still do not see any indication that they are wearing.
I ride at least once a week but usually more, race harescrambles/GPs and this last winter involved lots of wet and muddy riding. I clean the bike after every ride and use simple green and a scrub brush on the chain/sprockets followed with a good rinsing from the garden hose. After that I spray it down with WD40 to get the water off...once it dries I lube it up with Dumond Tech chain lube.
I'm due for new chain/sprockets on my RM250 and I am going with a Regina non-ring chain (just for comparison) and Sunstar sprockets...unless somebody has an alternate recommendation for good, inexpensive (I don't mean cheap though!) sprockets.
By the way, I heard somebody say that Ironman sprockets are hard on hubs because they don't have very much contact area...anybody know anything about this? Also heard they are 'too' hard and this results in a drive that is too jerky...don't flame me, just repeating one of the many rumors that one hears! I can't imagine that with all the shifting, accelerating, braking, bumps, etc that one could even sense such a thing...
Posted March 27, 2007 - 09:46 AM
... heard they are 'too' hard and this results in a drive that is too jerky...don't flame me, just repeating one of the many rumors that one hears! I can't imagine that with all the shifting, accelerating, braking, bumps, etc that one could even sense such a thing...
If anything, the Ironman should be "springier" than an equivalent aluminum cog. I agree with you that either gear is still a disc of metal bolted directly to the hub, and how anyone can profess to be able to feel the difference at all is beyond me.
But it will make a good addition to the product line at my Black Feather Racing Products division.
  • yz007f
Posted March 27, 2007 - 05:40 PM
Pro Taper sprockets are a good choice if you want to stay with Alum ones.
  • oldfordz
Posted March 28, 2007 - 08:20 PM
Anyone use the Sunstar sawtooth (or staggered) rear sprockets?? I get a good season and a half out of mine and for the money, you can't beat them...they just aren't pretty...black only.
  • yzsurfer
Posted March 29, 2007 - 12:21 PM
I have the Ironman on my '00 426 and it still looks great. Been on a long time with a lot of Baja miles. Never felt any jerky ride or anything mentioned above. Used to go through Renthals regularly. Nuthin' but good things to say about the Ironman, I'll stick with them.
Jeff
  • CaseyWR450
Posted March 29, 2007 - 12:31 PM
I just got Primary Drive a sproket kit with an X-ring chain hoping it holds up well.
  • DrThumper
Posted March 29, 2007 - 01:27 PM
Second That :bonk:
  • Ganadore
Posted March 29, 2007 - 03:57 PM
Best bang for the buck = most anything thats not OE.......
  • rideawn
Posted April 02, 2007 - 08:29 AM
114 links for replacement chain on stock '07 gearing (13/49), correct?
  • Dirt Vader
Posted April 03, 2007 - 09:07 AM
Yes 13/49 114.
  • Hot  38 replies
  • Hot  47 replies
  • 3 replies
  • Hot  36 replies
