XR650R Fork Problem
9 replies to this topic
  • Halluci_n8
Posted January 14, 2007 - 04:12 PM
I have a slight dilemma with my fork. I broke the tab off the left fork tube that routes the brake line to the caliper. I have included a pic that shows which tab I am talking about. Its cast, and since its part of the fork tube, I am unsure of how to repair it. Tape seemed to work to get me thru the weekend when it happened, but I need a real fix here. A friend mentioned I should be able to weld it back on, but Im positive the heat will damage the fork internals.
Just looking for some ideas here, any help would be appreciated.
  • rebelventurer
Posted January 14, 2007 - 04:40 PM
First, you can weld the tab back on TIG would be the best way, though when you weld cast aluminum it weakens the surrounding metal, and tends to break again nearby. A total disassembly of the fork leg would be required and new seals after repaired. Second, and the cheapest would be to JB weld it, when done right the stuff works. You would want to mask off the area around the repair as not to make a mess with the epoxy. Be certain to give plenty of cure time before assembling the parts. Third, watch ebay and pick up another set of forks fairly cheap. Good luck, let us know what method you use.
Oh, welcome to TT.
  • porterdog
Posted January 15, 2007 - 05:10 AM
+1 JB Weld. Stuff is amazing. +1 masking, too.
Robert
  • BWP Jockey
Posted January 16, 2007 - 06:31 PM
To weld it , you will have to disassemble that leg.Try the jb weld first.
  • porterdog
Posted January 17, 2007 - 04:45 AM
Meant to say also that it's machinable, so if it goes TU you can grind it off and weld as normal.
  • Halluci_n8
Posted January 17, 2007 - 10:21 AM
JB Weld! Never even thought about it! Thanks guys, I will give that a shot and let you know how it works.
Also, I have experianced the pain of having the bolts snap where the right side STEEL peg brace mounts to the ALUMINUM frame... in sand whoops while tapped in 4th no less. I remember seeing on this site a company that offered a fix where the brace wraps around the frame, but cant remember who that company is or where to find them. Has anyone used this product on their 650's?
  • porterdog
Posted January 17, 2007 - 11:57 AM
JI remember seeing on this site a company that offered a fix where the brace wraps around the frame, but cant remember who that company is or where to find them.
http://www.animalhou...et/products.htm
Never used it.
  • xr650rkyle
Posted January 17, 2007 - 12:21 PM
Xr400's have a non metal white plastic clamp that holds the brake line.
If that would work, that would be an EASY FIX!
check it out on xr 400 fork legs....:lol:
  • Halluci_n8
Posted February 06, 2007 - 03:26 PM
Hey guys, I used a product called cold weld, basically the same slime as JB weld, and it worked great. Time will tell if it holds up under riding, but its stuck like mad on there.
Thanks for the help! :censored:
  • Boudroux
Posted February 06, 2007 - 05:00 PM
Never used it.
I have this foot peg fix and know several others who do and we are all very happy.
  • 22 replies
Honda XR650L 2017
  • 0 reviews
  • 3 replies
  • 17 replies
