WR400 Cam Sprockets
1 reply to this topic
  • chinesespaceman
Posted January 14, 2007 - 10:44 AM
Hi Guys,
Following from my queries regarding cam timing I have checked the tensioner and seems to be okay. It's not overly strong, but returns quickly and smoothly.
The chain wasn't sitting neatly on the sprockets, so I figured to replace it anyway and inspect the crank sprocket and cam sprockets. Not go to the crank sprocket yet as need to make a tool to hold the flywheel, but take a look at the wear on the teeth:cry: :lol:
I take it that this is heavy wear and not normal.
http://i132.photobuc...n/sprocket2.jpg
So what are my options. If I want minimum downtime, do I reassemble with new chain, adjusting the valve clearances whilst I am in there and order some new cams?
Assuming the cams need replacing, what are the best?
Are the hotcams good alternative to OEM?
Cheers
Gavin
  • Jekel
Posted January 19, 2007 - 06:42 PM
What year WR?
Are the teeth pitted and uneven?
Whatever route you go I would be sure to get the automatic decompression cam.
