All 2007 owners - Gearing Question
5 replies to this topic
  • dangermouse007
Posted January 14, 2007 - 03:56 AM
Hi Guys,
Question: have any of you need to change the gearing on the 2007, on my 2003 I ran 13/51 as it was really good for the woods, but I here the 2007 has got more bottom end then earlier years.... have you found this correct and found that the 14/50 gearing is now very good...??
Thanks
  • Derwud
Posted January 14, 2007 - 07:00 AM
I was thinking of droping the rear to a 49 or even a 48. I never use 1st gear.
  • RSWR450F
Posted January 20, 2007 - 03:41 PM
Mod. 2003-2006:
Primar reduction ratio: 62/22 (2,818)
Secondary reduction ratio: 50/14 (3,571)
Gear ratio:
1st 29/12
2nd 26/15
3rd 21/16
4th 21/20
5th 21/25
Mod.2007:
Primary reduction ratio: 61/23 (2,652)
Secondary reduction ratio: 50/13 (3,846)
Gear ratio:
1st 29/12
2nd 26/15
3rd 21/16
4th 21/20
5th 21/25
RS WR450
www.rsracing.cz
http://www.rsracing....YAMAHA_WR_2007/
  • Looks450
Posted January 20, 2007 - 04:58 PM
Mine came with 13/50 std, but after the first ride and not having enough legs for the long straights i went up to 14/50 and loved it.
The engine has so much more pull than my last one, and i find that i have to feather the clutch, not to get the motor to spool up, but to keep the power down so as not to lift the front to high.
  • Kyle Prior
Posted January 20, 2007 - 07:30 PM
When I get mine for desert riding what size gears should I put? Lots of higher speed sections where I ride..
  • 520Roost
Posted January 20, 2007 - 10:07 PM
true , i think it should pull a 48.
