Did i get my money's worth? (UK)
9 replies to this topic
  • Howzer
Posted January 13, 2007 - 12:26 PM
Folks,
I recently bought a 05 WR450f and the guy i bought it off (the bike is immaculate) offered me a box of spares for 150 british pounds here is the list can you help with prices???
Spares
1 x gear lever
3 x clutch lever (1 of 3 still sealed in Yamaha pack)
3 x rear sprocket (46t, 50t, 51t)
1 x pair fork oil seals (still in Yamaha sealed pack)
1 x pair fork dust seals (still in Yamaha sealed pack)
1 x Camshaft (still in Yamaha box)
1 x oil pump assembly (still in Yamaha box)
4 x wheel bearing (still in Yamaha sealed boxes)
1 x rear brake caliper guard
1 x Renthal fatbars (including mounts) (light use)
1 x spare top yoke
1 x standard header exhaust pipe (light use)
3 x foam air filter
2 x fork spring
1 x shock spring
1 x set of Acerbis hand guards (including fitting kit)
1 x clutch lever mount
1 x chain slider (front mounted) (still in Yamaha sealed pack)
1 x chain slider (rear mounted)
1 x clutch cable
16 x various engine seals (in Yamaha sealed parts bags)
2 x main jet 170, 175
1 x set front brake pads (still in sealed Yamaha box)
1 x front brake disk
1 x set of fork bushings
1 x front mudguard (light use)
1 x rear mudguard (light use)
2 x radiator cowl (left and right, light use)
2 x number board decal (yellow, new)
1 x combination spoke spanner (7mm and 9mm)
3 x front spokes
4 x rear spokes
  • glasseye
Posted January 13, 2007 - 12:30 PM
Time will tell if you got a good deal. Depends on how many of those parts you actually use.
  • Howzer
Posted January 13, 2007 - 12:39 PM
What i meant was if you were to buy these parts would the approx cost match what i paid? i know the Renthal bars alone are around 50 pounds here!
  • specialk6r
Posted January 13, 2007 - 02:43 PM
At the current exchange rate (1 US dollar = 1.96 UK pounds) that's probably a deal over here. You've easily got over a hundred dollars worth of seals and bearings, and the bar/triple clamp combo is another hundred +. If you do all your own repairs/maintenance and like having spares on hand, I'd go for it.
  • bigbluerider4life
Posted January 13, 2007 - 03:28 PM
id jump on that if i were you!
but why did he have so many extra parts? does the bike really need all that stuff because of its condition?
  • Howzer
Posted January 13, 2007 - 04:36 PM
No, the guy is an ex-Yamaha sponsored rider and is now with KTM so he sold off all the Yamaha bikes and spares, i snapped it all up and am very happy with it.
howzer.
  • David37
Posted January 13, 2007 - 08:30 PM
I would buy the parts, keep what you think you'll use and sell the rest on e-bay or sell to other 450 owners.
  • Beejay
Posted January 14, 2007 - 01:05 AM
You got a bargain with those spares, looking at the list, you will in future use a lot of that, like the ones in blue.
1 x gear lever
[COLOR="Blue"]3 x clutch lever (1 of 3 still sealed in Yamaha pack[/COLOR])
[COLOR="blue"]3 x rear sprocket (46t, 50t, 51t)[/COLOR]
[COLOR="blue"]1 x pair fork oil seals (still in Yamaha sealed pack)[/COLOR]1 x [COLOR="blue"]pair fork dust seals (still in Yamaha sealed pack)[/COLOR]1 x Camshaft (still in Yamaha box)
[COLOR="blue"]4 x wheel bearing (still in Yamaha sealed boxes)[/COLOR]1 x [COLOR="blue"]rear brake caliper guard[/COLOR]
[COLOR="blue"]1 x Renthal fatbars (including mounts) (light use)[/COLOR]
1 x spare top yoke
[COLOR="blue"]3 x foam air filter [/COLOR]2 x fork spring
1 x shock spring
[COLOR="blue"]1 x set of Acerbis hand guards [/COLOR](including fitting kit)
[COLOR="blue"]1 x chain slider (front mounted) (still in Yamaha sealed pack)
1 x clutch cable[/COLOR]16 x various engine seals (in Yamaha sealed parts bags)
[COLOR="blue"]1 x set front brake pads (still in sealed Yamaha box)[/COLOR]1 x front brake disk
[COLOR="blue"]1 x set of fork bushings[/COLOR]
[COLOR="blue"]1 x front mudguard (light use)
2 x radiator cowl (left and right, light use)[/COLOR]2 x number board decal (yellow, new)
[COLOR="blue"]1 x combination spoke spanner (7mm and 9mm)
3 x front spokes
4 x rear spokes[/COLOR]
  • SXP
Posted January 14, 2007 - 07:39 AM
That's a smoking deal.
  • Howzer
Posted January 14, 2007 - 10:33 AM
Thanks for the feedback guys, much appreciated, i'm really happy with all the bits and i will use alot of them, had the bike out today for the first time and it's a stormer, glad i got it!
Howzer (Garry)
