whats the plus and minus with a larger or smaller rear sprocket on xr 650l
33 replies to this topic
  • martinfan30
Posted June 09, 2008 - 01:10 PM
#21
Did you notice the date of the last reply before yours?:thumbsup:
  • rocky one
Posted June 09, 2008 - 03:33 PM
#22
:thumbsup: sure did :busted: just got bored :busted:
  • HeadTrauma
Posted June 09, 2008 - 03:46 PM
#23
Keep in mind that the power bands from other bikes are the standard narrow type. The XRs have special wide power bands that are not common to all the other brands. They come in the same colors, but usually have a "W" designation somewhere in the part number to denote "wide."
I know I'm just perpetuating a dead-thread revival, but I figure someone might still learn something. :thumbsup:
  • martinfan30
Posted June 09, 2008 - 04:40 PM
#24
:busted: sure did :ride: just got bored :ride:
I hear ya. No offense meant!:thumbsup:
I know I'm just perpetuating a dead-thread revival, but I figure someone might still learn something. :busted:
I actually prefer the standard "narrow" type.. In red.
The "W" designation is definately a plus in wide out, desert riding though.
:cry:
  • Defesio
Posted June 09, 2008 - 04:47 PM
#25
If the stock is 15:45, and I need more final speed (more street than dirt).
What´s your advice?
  • MXJunky
Posted June 09, 2008 - 04:55 PM
#26
And I thought I had Jungle Fever..
You too, eh?
  • martinfan30
Posted June 09, 2008 - 04:59 PM
#27
What´s your advice?
If you can find a 16 tooth C/S sprocket, try that. There may be some clearance issues, not sure havent tried a 16.
Or , find a 44 rear.
  • Purcell69
Posted June 09, 2008 - 05:18 PM
#28
I went to a 44 tooth Renthal rear in aluminum for the gas mileage, but I have a 42 in steel on the way. I've been using the R rear sprocket and drilling out the bolt holes to 10mm (3/8") vs. the 8mm for the R model. Huffa2 is running a 42 tooth rear in aluminum, not so much for top end, as it is for economy. With a 42 rear, I can swap the front to a 14 to return to stock gearing, mathmatically the same as (15/45) or go to a 13 for off-roading.
-Joe
  • rocky one
Posted June 09, 2008 - 05:21 PM
#29
don't make a 16 tooth for the 650L...no clearance...like MARTINAN30 said..try to get a 44 tooth rear or the last i heard MISSION MOTORSPORTS was having a sell on the "W" power bands...W meaning wide for the L model....let us know if your having troubles or just give mission motorsports a call..
  • martinfan30
Posted June 09, 2008 - 07:14 PM
#30
No they dont. The 16 tooth is a Yamaha part and it fits. Hopefully Captain Midnight will chime in, as I cannot find the thread he posted the part number....
EDIT: Found it. The part number is on the second page in this thread...
http://www.thumperta...aha part number
  • jonr3
Posted June 10, 2008 - 04:31 AM
#31
This "R" rider found a unique way to carry an extra rainbow wide powerband...
:thumbsup: :busted: :busted: :ride: :ride: :cry: :cry:
  • HeadTrauma
Posted June 10, 2008 - 08:27 AM
#32
Didn't take long for the running gag to become just gagging. :thumbsup:
  • Defesio
Posted June 10, 2008 - 02:21 PM
#33
Purcell69: Tanks for the tip, I´ve been looking for the Renthal 42(154V-520-42GRSI), but no succes.
Any ideas?
  • Purcell69
Posted June 10, 2008 - 05:25 PM
#34
I got mine used on ebay for $10, barely used. The other possibilty is a JT for the R. You'll still have to drill out the bolt holes, but the sprocket bore and bolt pattern is the same. You can also check for a 1990-1995 XR250, as it uses the same sprocket.
-Joe
