WR426F hot start stuck, Please help!!
4 replies to this topic
  • jolleyr
Posted January 10, 2007 - 11:49 AM
I went to use my hot start the other day and it is stuck:mad: . I loosed the nut on carb and tried to pull the plunger out and was unable to. Does anyone have a quick fix. I tried LPS and carb cleaner. At this point nothing is broken. Any advice for the Newbie would greatly be appreciated.
  • redswr
Posted January 10, 2007 - 01:01 PM
i had the same thing happen about 15 minutes into a hour long race. couldn't get it back in and it ran terrible. after i got it back into the pits i just tapped on it with a small hammer and it went in.
ps: just tap it in - Happy Gilmore
  • huffster
Posted January 10, 2007 - 01:04 PM
If it's stuck, you might be able to get it loose with a chemical agent....If not, it has be be removed by force, somehow.
  • Birdy426
Posted January 10, 2007 - 05:13 PM
It's corroded into the bore. You might try taking off the carb, positioning it with the hot start plunger up, and applying some Rust-Lik or PB Blaster. Let it soak in good, then heat it up a bit with a heat gun...
Good luck.
Also, try a search and see if you can find other creative solutions to getting the plunger out. This is really a fairly common problem.
  • jolleyr
Posted January 10, 2007 - 07:55 PM
Thanks for the help guys!!! I will give it a try later tonight and see if i can get it out using one or both of your methods.
