GYTR Flywheel Install
3 replies to this topic
  • torrmentor
Posted January 09, 2007 - 09:56 AM
I'm planning on installing a GYTR flywheel on my new '05 YZ450 and was wondering if someone could answer me this:
On the YZ 250 2-stroke the plastic ignition cover is easily removed to expose the flywheel/stator. But on the 4-stroke it looks externally as if I may need to get passed the oil somehow since the fill hole is incorporated into the engine cover on that side.
Is it a simple pull-the-cover-and-get-out-the-flywheel-puller procedure like with the 2-stroke, or is there more to it????
I haven't taken delivery of the bike & manual yet so I can't really check it out yet on my own.
Thanks all for the advice as to what's beyond that cover....
Posted January 09, 2007 - 12:26 PM
If you start the engine and run it just long enough to purge the sump (60-100 seconds), you can open the ignition cover with the bike upright and loose only a few drops of oil. Have a new gasket handy.
It uses the same puller as the two-stroke, and the procedure is otherwise exactly the same.
  • torrmentor
Posted January 10, 2007 - 10:57 AM
What about with bike on it's side???
Posted January 10, 2007 - 11:53 AM
You can do that, too, but there's no need to once the bike's been run for a couple of minutes.
  • 10 replies
  • Hot  47 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • On January 15, 2017
  • 5 replies
