Heavy Steering
12 replies to this topic
  • Monster04
Posted January 08, 2007 - 02:05 AM
How can i make my 04 turn easyer.
Ive added a storm linkage. is there anything else
  • Ga426owner
Posted January 08, 2007 - 07:57 AM
what is your sag set at with the Stormlink?
  • Monster04
Posted January 09, 2007 - 12:32 AM
its set at 105mm
  • BergArabia
Posted January 09, 2007 - 03:50 AM
What about the front tire?
  • bg10459
Posted January 09, 2007 - 06:49 AM
Raise the fork tubes in the clamps. The first line under the cap is 5 mm, the second is 10 mm.
  • Ga426owner
Posted January 09, 2007 - 08:09 AM
yes this will help also - I believe mine is set at between 7mm-10mm
Front tire definitely makes a difference (michelin Starcross on mine) as does sag and rebound/compression settings..try slowing down the shock and fork rebound a couple for clicks - 2 X H or speeding it up depending where it is set at now
103 - 105mm sag is the range
  • flintlock28
Posted January 09, 2007 - 05:11 PM
If you simply want to raise the fork tubes a couple mm or so, does it just require you to loosen the pinch bolts on the triple clamp, slide the tubes up the appropiate amount, and then retighten them??
I would assume that's it, but before I move mine, is there anything else required to do?? I don't want to have binding or anything.
Thanx
Posted January 09, 2007 - 06:00 PM
That's pretty much all there is to it, yes.
  • flintlock28
Posted January 09, 2007 - 08:15 PM
Thanks gray...just wanted to make sure.
I run the Stormlink also, and it definately helps 03' and 04' models. I've never moved my tubes from the stock 5mm setting, but I just might have to experiment. I'll try going to 7mm, and see what happens.
  • Monster04
Posted January 10, 2007 - 02:44 AM
front tire is a dunlop 756 and the forks are 10mm above the clamps.
would the applied clamps make much difference
  • flintlock28
Posted January 10, 2007 - 03:33 AM
I'm not 100% sure, but I think I read that running BOTH the Stormlink, and different offset clamps, can be a nightmare to dial in. Seems to be you have to run one or the other, but not both.....maybe other's will confirm this.
I used to run the 756 up front, and I recently switched to a Pirelli Scorpion Pro (might be called a m-83 also?), anyway, the Pirelli Scorpion Pro does give me sharper turning compared to the 756.
  • Ga426owner
Posted January 10, 2007 - 05:40 AM
confirmed - don't do it unless the offset of the triple clamps are stock....Applied does have clamps with a offset similar to what Reed was using then that will assist in turning...remember he also had a non stock link from yamaha - totally diiferent than a Storm Link:thumbsup:
Posted January 10, 2007 - 08:21 AM
The Storm link simply changes the rear ride height, and thereby the head angle by tilting the entire bike. Reed more than likely had a rear linkage designed to alter the rising rate of the shock, as do many other pros.
  • 5 replies
  • Hot  113 replies
  • Hot  36 replies
  • Hot  30 replies
