426 countershaft seal oil leak.....?
3 replies to this topic
  • DTYZ426
Posted January 07, 2007 - 10:34 PM
Is it recommended to replace the steel collar when replacing the seal and
o ring? The collar looks good. I combed the manual and could find nothing related to the countershaft seal.
Posted January 07, 2007 - 10:45 PM
Unless there is a significant groove in the collar, reuse it. If there is a groove, it may bind the lip of the new seal and cause it to leak.
  • DTYZ426
Posted January 07, 2007 - 10:50 PM
Thanks a bunch, grayracer
Posted January 08, 2007 - 06:54 AM
As you mentioned, there's an O-ring under the collar that seals it to the shaft, too, and you may want to at least check it. It can be removed with a small pick or a bent safety pin.
  • 5 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  30 replies
