White goop in black vent hose....
6 replies to this topic
  • djtroy
Posted January 07, 2007 - 07:13 PM
Can you guys tell me what the white goop that came out of the black vent hose that runs up on top of the cylinder head might be?
I was changing my oil and I noticed that there was a big blob of white stuff that fell out of the black tube buy the oil filler cap it looked like white lithium grease but i know its not. Could it could be some oil/water combo I recently dumped it in a muddy swamp by mistake.
  • FFRacing79
Posted January 07, 2007 - 07:15 PM
Oil mixed with water will make the "goop" you are refering to. It is probably just moisture that mixed with the oil vapor. JMO Tdub
Posted January 07, 2007 - 07:45 PM
That is, atmospheric moisture. Most likely condensation and nothing to worry about. To be sure, check the condition of your oil and your coolant. If they are both free of any evidence of contamination by the other, you're fine.
  • djtroy
Posted January 08, 2007 - 06:59 AM
Yes the oil was black...... but the coolant had water in it :lol: :confused:
All jokes aside it looks fine
  • smason8
Posted June 08, 2007 - 04:42 PM
I am having this same thing happen. I was in first gear doing a burn out in my garage, shut it down and looked at the floor. I waspouring that white goopy oil out of the cylinder head vent tube. Is this a problem? Shouldn't there be a check valve to keep the oil in the engine?
  • black_n_blue_thumper
Posted June 08, 2007 - 09:34 PM
Just curious, why were you doing a burnout in your garage. :thumbsup:
  • MikeDD
Posted June 08, 2007 - 10:08 PM
To break in his new tires? ehehe
  • 5 replies
  • Hot  79 replies
Motocross
  • Hot  491 replies
  • Hot  47 replies
