Fuel Screw Reassembly Question
1 reply to this topic
  • AMA_whymee
Posted January 05, 2007 - 02:43 PM
Hi all...
Since my 06 YZ450F was all apart for bearing greasing I decided to install a bigger pilot & a GYTR fuel screw. Especially after I installed the Dr. D. Full exhaust I figured I needed the pilot. All was good as I tightened up the last bowl screw. I just happen to look down at the top of the center cases and seen a teeny tiny o-ring & washer. Oviously came from the fuel screw I took out, but didn't see it drop off the stock fuel screw.
Q is in what order do these parts go on the fuel screw for reassembly?
I looked up the online fische but could not make a determination what went where. My guess is: Fuel screw, Spring, washer and o-ring. The o-ring would seat against the carb body.
Am I correct?
BTW: Glad I didnt have to pull the carb off. What PITA that will be....
Thanks in advance!!!
Stan
Posted January 05, 2007 - 03:04 PM
Am I correct?
Yes, you are.
  • 0 replies
  • On January 15, 2017
  • 5 replies
  • Hot  50 replies
