How to:
CRF250R front number plate on your 250X
This is a UFO brand front number plate. I’m guessing that this plate is a little different than the other plates out there.
The 1st step that I took is to cut off the large center tab. I used my dremel drill and took my time to make sure the finished product looked nice. Here are my pictures
2nd step that I took was to apply heavy duty Velcro to the sides of the new number plate.
The 3rd step was to drill holes in to the two tabs on the top of the number plate I used a 1/8” drill bit and made the hole oblong.
The 4th step was I took my light hook up and wrapped it up with plumbers tape to protect it and then used duct tape to secure it, and I placed heavy duty Velcro on the sides of the lower triple clamp.
The 5th step was to place the number plate on the bike. Make sure you fish the long tab on the top under the break line 1st. Then place it on the Velcro.
Next I attached the top holes that I made in the number plate to the holes for the bolts for the head light number plate with zip ties. Don’t tighten them up at this point just get them started.
Next step I slowly started tightening the zip ties from one side to the other. Take is slow and step back from time to time to make sure the plate is level and square. Then after you’ve got it tight cut off the tails.
Then she’s done.
