Should i carb my 06 650l?
10 replies to this topic
  • TDC71
Posted January 05, 2007 - 01:21 PM
Hi guys thanks for all the help getting my bike to where it is.:lol: I"ve got the Hotcam stage 1,Uni filter,Dave's mods with a Dyna-jet chaser and a 165 main,supertrapp with 19 disks.Bike pulls hard wheelies through second so I was debating whether a carb uprade is needed and if it makes that much difference after what I have done already.So will it do any more and if so which carb works best?
Todd
  • TDC71
Posted January 05, 2007 - 01:22 PM
And the snorkel is history too plus I drilled a few holes in the top for more O2
todd
  • rebelventurer
Posted January 05, 2007 - 03:22 PM
Definately upgrade! best are either edelbrock, readily available from ebay $399, or keihen 41mm FCR from xrs only $525. :lol:
  • TDC71
Posted January 05, 2007 - 03:48 PM
Thanks Rebelventure will check it out.
Todd
  • sbenja2003
Posted January 05, 2007 - 05:50 PM
I just put an edelbrock on mine I also have the stage 1 hotcam xrs only header with e-sieres muffler and 10.0-1 je piston. Now it pulls the front all the way thru 3rd. The carb is easy to adjust best mod so far.
  • tirebiter
Posted January 05, 2007 - 08:03 PM
If your bike's running primo, and you don't ride at different elevations on a weekly basis, then no. Keep your stocker.
Personally, I run the Edelbrock for ease of adjustments for different altitudes,
the stocker being a pain to re-jet all the time..
  • jbird710
Posted January 05, 2007 - 08:42 PM
Even after doing the Dave's mods, the replacement Edelbrock still seemed to make a world of difference to me.
  • XR650L_Dave
Posted January 08, 2007 - 08:44 AM
Throttle response with the CV carb will always be crippled compared to a manual-slide carb.
Dave
  • TDC71
Posted January 08, 2007 - 02:28 PM
Gonna take the Edelbrock dive want to be able to change my jets out quick like Tirebiter can do.Just joined a dualsport group and elevation changes are on the horizon. Thanks for the input everyone.
Todd
  • rebelventurer
Posted January 08, 2007 - 03:22 PM
The edelbrock has a feature called dial a jet, to rejet just turn the dial, key with these carbs is a needle that will work within the given range of jet adjustment.
  • TDC71
Posted January 08, 2007 - 05:33 PM
Thanks for the info Rebelventure, thats even cooler than swappen out the jets, I thought it was come kind of external accessed jet system:bonk:
Todd:thumbsup:
