IMPORTANT-faulty 07 air filters...make sure yours is not the same.
133 replies to this topic
  • Hunter245x
Posted August 29, 2007 - 08:59 AM
I bought a 2007 wr250f in Aug of 2007 - ran it for around 10 hours before i noticed the hole in the air filter. I simply ran a set screw with a allen head into the hole with some lock tight. It looks like a permanent fix. Dust was in my carb so I removed it and cleand it in and out. How long do you think it takes until a problem can arise? Top end wear? 10, 20 50 hrs in dusty conditions. My bike still runs good but am worried about the long term. Any thoughts?
  • kodiak7
Posted August 29, 2007 - 09:54 AM
has anybody talked to yamaha about this yet.... im curious about what they have to say
  • chevytrkn1
Posted August 29, 2007 - 01:56 PM
Ya i just picked mine up last week, and it was the one with the hole all the way through, did not know to look at it tell i got it home. Just plugged it with a plastic push pin and high temp sillycone
  • debun
Posted August 29, 2007 - 06:54 PM
Ha s anyone found this on a YZ or is this only on the WR's
  • msgbean
Posted August 30, 2007 - 09:45 AM
Of course it on the YZs. That what the hole is for to put a bolt through.
  • debun
Posted August 30, 2007 - 01:30 PM
I looked at mine and I have a metal washer behind the screw so it doesn't seem like any dirt can get in. Am I missing somthing because I have a yz 250f 2007 and can't seem to find a problem
  • WR_Dave
Posted August 30, 2007 - 01:53 PM
You can't find a problem because on the YZ's the filter cage needs the hole for the bolt and washer, it's the WR's with the YZ cages that are having the issues.
  • slnutt
Posted October 11, 2007 - 05:08 PM
My bike is serial number 2355.....just bought it last week (October 2007). What are the chances that it has the updated cage?
Thanks
  • esbotto
Posted October 11, 2007 - 05:57 PM
50-50. Be on the safe side. Pull it out and make sure. I bought mine in February and they told me it had the right cage. Thankfully I just rode down the street before I pulled it out and discovered the hole.
  • camaroman7d
Posted January 12, 2008 - 08:59 AM
Just bought a leftover 07 last month and the filter cage is fine (no hole). Don't know if the dealer fixed it or if Yamaha finally has it figured out. I also don't know the build date. Where is that found?
  • maincrash
Posted January 25, 2009 - 06:43 AM
I just bought 07 wr450 used, got a great deal then i read this thread, grabed my flash light (11:30pm) out to the shed I go.
2700 km with a big old hole THAT SUCKS.
Oh well, starts good runs great I'll plug the hole and ride it.
  • mightymart
Posted January 25, 2009 - 12:58 PM
Problem solved!! An sponge ear plug with some loctite, stuffed the hole.
I did the same thing !
I also told Yamaha uk back in April 08 when I got the bike & they knew nothing about it :banana: Nor did they want to put it right, I must admit I had already pluged the hole & was hopeing for a freebie filter holder.
  • TRUE_2_YAMAHA_001
Posted January 25, 2009 - 10:56 PM
i don't know if they are suposto come out but mine does. which isn't saying much considering the topic. time for a uni filter to go on her.
  • mightymart
Posted January 26, 2009 - 05:34 AM
Whats coming out ?
