XR650R Help
4 replies to this topic
  • Itchy
Posted January 04, 2007 - 08:15 PM
I've got a really weak spark (compared to my 450 EXC). The service guys
I've talked to say the "pulse generator?" will either work or it wont.
I've played with it for a while put it down now I'm back. Thanks for
the help with the vacume line fit right under the tank in the rubber
isolator < I'm blind. It will start and run < shortly) on ethier, The
carbs been cleaned professionaly and I talked with the guy that did it
explained to him what the situation was <when I did get it started
before I could putt on it till about 2000rpm< guess)then it starved for
fuel. Went through the carb again and all I can blame it on is the weak
spark < not the bright blue/white I'm used to. Can some one give me
idea for what to try next.
Honda who wants about 100-150 just to look at it says if it sparks at
all it will run.
If the advice is to go through the carb again I'll do it but I don't
think that's it. < But what do I know :lol:
Thanks in advance.
  • needsprayer
Posted January 05, 2007 - 05:39 AM
Weak spark would lead me to try a new sparkplug first.
Starved for fuel could indicate an air leak on motor side of the carb.
  • Itchy
Posted January 08, 2007 - 04:18 PM
Thanks looking into it
  • ToXicD
Posted January 10, 2008 - 04:32 AM
Well that is not necessarily true. You can have electronics fail but still work, just not properly. Electricians will what is called megging. It is a test to see how much deterioration or breakdown a motor, coil, or wire may have.
  • Billahjack
Posted January 10, 2008 - 07:35 AM
Does it start easy? If so, i would say that you have sufficient spark.
I would check your jet sizing, air filter, intake connections (Carb to rubber boot, rubber boot to head), carb breather lines, carb mechanical operation (slide linkage is working, choke plate-is the backfire flapper still there?), fuel petcock, fuel sceen in tank above petcock, fuel flow (loosen brass screw at bottom of carb float bowl near hose to open up drain), and smog block-off plates if applicable on your model.
That's about all I can think of at the moment. Its hard to troubleshoot something like this without being able to look at it.
Honda XR650L 2016
  • 0 reviews
  • 22 replies
Washington
  • Hot  32 replies
  • 3 replies
  • Hot  60 replies
