Adding oil to Forks?
3 replies to this topic
  • rep
Posted January 04, 2002 - 07:48 PM
Any easy way to add oil to forks besides pulling out of triple clamps and removing caps? Forgot to look to see if the bleed screw in the cap provides a direct passage big enogh to add oil through.
I set mine at the factory level of 135mm and worried it may be too soft for my bad to the bone 140 lbs.
thanks
rep
  • skthom2320
Posted January 05, 2002 - 06:56 AM
You can add it through the bleed screw. 14cc is about 10mm in oil height.
Regards,
Steve T
  • rep
Posted January 05, 2002 - 08:51 PM
thanks man!
  • yzernie
Posted January 06, 2002 - 07:46 PM
I remove my handlebars, loosen the top clamp bolts and pull the caps. I have tried to put oil in via small bleed hole and it just takes forever. Ten minutes and I'm back on the track.
Ernie
