Making a YZ426F Faster
25 replies to this topic
  • 2000 yz426f
Posted January 02, 2007 - 01:12 PM
I have a 2000 yz426f and I am getting a little bored with the power it makes. It is totally stock except for schmidt forks and shock and a white brothers r4 exhaust with header. What parts are out there to make this bike faster for under a few hundred bucks? I want to get an autodecomp cam from hotcams but will it really make it noticably faster?
  • milje
Posted January 02, 2007 - 01:48 PM
Check out the Yamaha forums a bit farther down from this, they should be able to help you out. I'm sure there's some free mods you can do (it seems like most bikes have free mods, or at least really easy ones that give decent results).
  • gialinn
Posted January 02, 2007 - 01:59 PM
If you've just done the pipe, most bikes respond well to opening the airbox, getting a better filter, and rejetting. Some people have had good luck with POWERNOW inserts for the carb, still around $100 bucks i think.
  • 642MX
Posted January 02, 2007 - 02:43 PM
13.5:1 piston, set of Hot Cams, JD jet kit..... It depends on how much money you want to spend. Just freshing up the motor will make a world of difference.
  • JSanfilippo
Posted January 02, 2007 - 06:20 PM
A 426 is a little too big for an 8 year old don't you think?
  • 2000 yz426f
Posted January 02, 2007 - 06:46 PM
I'm actually 18 how do I change the age on my profile. Do you really think an 8 year old would be using this forum?
  • pamatt
Posted January 02, 2007 - 07:27 PM
Send your head and carb to Tom Morgan. Then install a high comp piston.
  • JSanfilippo
Posted January 02, 2007 - 09:38 PM
Go to user control panel
Then edit profile
then put in your real birthday
BTW eight year olds don't use this forum (not that I know of), but there are plenty of adults that act like eight year olds:bonk:
  • Fastest1
Posted January 03, 2007 - 11:15 AM
What type of riding are you doing that the 426 is too slow? What gearing do you have at the moment? If you are tapping out a 426 on a mx/sx track you should do 2 things, (1) Call Yamaha and get sponsored and or (2) go somewhere besides a drag strip.
  • 2000 yz426f
Posted January 03, 2007 - 12:49 PM
I do mostly desert riding and have stock gearing.
  • 30-A rider
Posted January 03, 2007 - 01:21 PM
EXACTLY what I was thinking. Far as power goes 99% of people can even utilize the power of the old YZ400. let alone the 426 or 450 on an MX track.
He did say desert riding was his primary terrain. If its soft sand best performance mod I would do is get a 500cc 2 stroke! If its baha like terrain...well the XR650 is still and has been for years king! Rememer, the 426 is primarly designed for motorcross.
  • YZ426F Rider
Posted January 03, 2007 - 01:32 PM
I have never been riding and thought to myself "If I only had more power..." I have wanted broader/smoother power but never MORE. I have however wished many, many times for more traction or better suspension...two things that more power would only make worse.
  • Goosedog
Posted January 03, 2007 - 03:54 PM
Well said. :lol:
  • flintlock28
Posted January 03, 2007 - 04:12 PM
I've wanted more Power only when play riding, and having a long straightaway where I wanted to just accelerate as quickly as possible. It would be fun to see my buddies face when I pulled away from him......he's on a 2003 Yz450f, and I'm on a 2004 Yz450f. Other than that, there's no way I can truly utilize the stock power on a MX track, to it's potential.
  • Kyle Prior
Posted January 03, 2007 - 04:26 PM
What do you want more power in? Do you want the bike to have a higher top end, or harder acceleration? It seems to me that since you are in the desert, you want a higher top end, which would be gearing, not power. For me, I run a fairly modest 14/47 in the desert, but many people go to a 45 or 46 rear sporcket.
  • mpl239
Posted January 03, 2007 - 08:57 PM
Power vs. speed, do you understand the difference? Anybody can hall ass down a dirt road. If you are bored with the 426, challange yourself to some difficult single track. You will find the 426 has more power than you can use there. Not speed, but raw power to git up them hills. Make sure you are riding with others so when the power gets away from you and you bust your ass, there will be help near by.
  • Kyle Prior
Posted January 03, 2007 - 10:08 PM
I learned this on a recent dune trip... The bike has an insane amount of power, it crazy yet fun.
  • 2000 yz426f
Posted January 03, 2007 - 10:28 PM
Ok after reading other's thoughts I need to restate my original statement. I am looking for more speed, not power. I ride with friends who have new crf450x's and I don't have the money for one, so I want to make my bike faster.
  • torqueme
Posted January 03, 2007 - 11:56 PM
If you're looking for more TOP speed get the biggest front sprocket you can find & the smallest rear. oh yea, & pucker-up...:lol:
  • Kyle Prior
Posted January 04, 2007 - 12:07 PM
Yeah, go with like a 15/46 sprocket setup. Youll almost lose the ability to wheelie, but the acceleration is still nice and itll hit somewhere around 85-90 I think.
