ZipTy Racing Carb mod?
11 replies to this topic
  • Ga426owner
Posted December 31, 2006 - 11:15 AM
Has anyone had ZipTy Racing modify their carb? I see they have a new mod service for a 100.00 - what is it and what are the results?
  • FOZZ
Posted December 31, 2006 - 06:11 PM
Good question ?
I got my carb off & want to do a few things since its off..
That AP mod confuses me :lol:
  • Ga426owner
Posted January 01, 2007 - 08:21 AM
Good question ?
same here - I will call ZipTy tomorrow. The AP Mod is the other option
  • flintlock28
Posted January 01, 2007 - 08:23 AM
Doesn't the AP mod only apply to the 426???
  • ncmountainman
Posted January 01, 2007 - 08:39 AM
they do something to the emulsion tube orifice(make it bigger i beleive) for better atomization down low. they also have a special needle. and also offer a anodized alum hot start nipple. and something about a magnetic carb drain plug.:lol: the plug and nipple are extra though. tell them to wire your AP (someone told me JD has a special oval shaped oring for this,but i don't really know)and time it for optimum results,might as well set the float level while their in there:ride:
  • Ga426owner
Posted January 01, 2007 - 09:34 AM
here are links for both as well as
Redbeards AP mod
http://www.ziptyraci...spx?id=MTUxOQ==
http://jdjetting.ser...page=1
http://www.thumperta...ad.php?t=374181
  • FOZZ
Posted January 01, 2007 - 12:43 PM
Thanks Fellers,
Im gonna give them a call also & see what other stuff they can tune up..
  • Ga426owner
Posted January 09, 2007 - 05:12 PM
I sent my carb to ZipTy last week ...it should be here by Friday - correctly set AP mod wired / duration squirt measured and emulsion tube added and pretested and few other tricks by the folks at ZipTy. They say 1.0 to 1.5 hp increase possibilities and a YZF carb that will not ever bog :lol:
I will test and report on this.... ZipTy folks were fantastic to deal with - and I learned some tips on Fuels and other
Steve @ ZipTy you are da man! :confused: :confused: :crazy:
  • lastchild
Posted January 09, 2007 - 11:12 PM
I sent my carb to them a while ago...I've had it for a few months but have never reported the results due to the fact that I'd been riding mostly at altitude and was having trouble getting it jetted right. Yesterday I was finally able to ride it at a normal elevation...the things rips. The carb mods that Zip-TY did were spot on.
They wired the AP and changed the emulsion tube among other things. They didn't change the needle as someone else has posted...it's still the stocker. I also think they tinkered with the diaphram...there were a bunch of marks made with a sharpie around it. I can't say for sure...I just popped the carb in as soon as I got it...I really should have opened her up to see exactly what they did.
Not that it was lacking in power before, but now I really have to work to keep the front wheel down.
Very crisp.
  • SUnruh
Posted January 10, 2007 - 05:45 AM
they install the Factory Pro jetting kit.
there is more too it than just an emulsion tube.
the carb had the plugged MAJ hole drilled out and a then tapped to accept a MAJ.
the new (thinner) needle then works with the new emulsion tube (which has 4 holes on a side, 180 degrees apart).
it is not worth the $100 for them to do it. well, except for if you screw it up you are out 600 for a new carb and if they screw it up, well, you get a new carb. so call it 100 towards insurance if you will. all the work takes 10 minutes to do. provided you measure everything 3 times over and re-read the instructions 3 times to ensure you are doing it correctly. serious pucker factor involved the 1st time you drill on a $600 carb.
the zip-ty price for the kit is less than what Factory Pro charges and the zip-ty kit with all the magnetic parts and nuts and stuff is a real bargin.
after the kit is installed, your MJ will drop in size about 12 steps. (ex 175 -> 142) due to the smaller needle diameter and greater atomization of the fuel.
  • Ga426owner
Posted January 10, 2007 - 06:01 AM
SUnruh - whats happening man? Thanks for chiming in on this - have you done this? I toyed with doing just the AP mod...but I think this is only part of what performance gains can be done to the carb. I spoke to a few and really liked what results the ZipTy mod gives....to me well worth a Cnote....I ain't drilling no carb.....:lol:
The mj drop 12 steps - is this for the CRF? They mentioned the jetting is a little diff for the red vs the blue. Anyway when I get it - I will see what jets they swapped and post this - They did tell me the NFLR needle for the Yami 06/07 is a little lean and to go back to the stock needle after this mod.
  • lastchild
Posted January 10, 2007 - 02:47 PM
The needle is stock on my Zip-Ty modded carb.
  • 10 replies
  • On January 15, 2017
  • Hot  28 replies
