rich or lean
5 replies to this topic
  • BlackMercedes300e
Posted December 29, 2006 - 11:02 AM
Does adding a white bros slip on and removing airbox lid make the bike rich or lean?
  • Robhibbert
Posted December 29, 2006 - 11:14 AM
It will run Lean
  • RutRipper
Posted December 29, 2006 - 11:17 AM
yep, leaner
  • BlackMercedes300e
Posted December 29, 2006 - 11:35 AM
should i adjust the fuel mixture screw in or out?
  • Robhibbert
Posted December 30, 2006 - 12:35 PM
You need to fit a bigger main jet and probably a pilot jet and raise the needle.You should learn abit more from the jetting section.
  • jandmsuburban7
Posted December 30, 2006 - 10:47 PM
Go to Indy and performance mods for carb jetting. Its good stuff. Dont ride your bike without making the carb changes too in addition to the Pipe and airbox. You will be very lean. I am hearing a JD jet kit is the best for our steads. Thanks, Jason
