TM Designworks chainslider won't fit 2006 ?
4 replies to this topic
  • Yamahafan
Posted December 28, 2006 - 05:34 PM
I just tried to install a TM Designworks 2 stage Chain Slide-n-Guide chainslider on my 2006 YZ450F. The top hole matches up perfectly, but the bottom hole is 8 to 10 mm short. Anybody else have this problem??
I tried to call TM Designworks, but they are on vacation from 12/19 through January 1st. I think they may have put the wrong part in the bag.
  • vpmx
Posted December 28, 2006 - 05:46 PM
Try giving Zip-Ty Racing a call at 1-760-244-7028. I just ordered a TM Design kit for my '07 YZ450F from them. I installed two sets of TM Design kits on my other bikes last year without a problem. My guess would be you the wrong part or a defective one.
  • Drfletcherdc
Posted December 28, 2006 - 06:09 PM
Mine fitted perfectly, except the allen bolt holding the stock slider on was stripped.
  • WILD_FX
Posted December 30, 2006 - 11:05 AM
This happendd to me three times in a row !!!
  • Yamahafan
Posted January 03, 2007 - 05:46 PM
After contacting TM designworks and explaining my sistuation it appears that Motosport has their head up the a$$. Their entire inventory is mislabeled. They are sending out the 2002-2004 chain slider in bags labeled 2005-06. The only difference between the 2002-4 part and the 2005-07 part is that the 2005-07 part has noise suppression foam covering 3/4 of the length on the inside of both the top and the bottom while the 2002-04 part foam only covers the rear 40% of the inside. Also the bottom whole on the 2002-04 part is 3/16 farther forward than the 2005-07 part.
DO NOT ORDER THIS PART FROM MOTOSPORT UNTIL THEY GET THIS STRAIGHTENED OUT!!!!!!!!!!!
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 0 replies
  • Hot  113 replies
  • Hot  38 replies
  • 10 replies
