LED turn signals
7 replies to this topic
  • dedminst
Posted December 27, 2006 - 07:22 AM
I installed, or at least I tried to install a set(4) of mini LED turn indicators on my 04 XR650L yesterday but they would not blink. They would only illuminate. Does any one have a solution?
  • cleonard
Posted December 27, 2006 - 07:38 AM
The LED's don't draw enough current to operate a standard flasher. You need a flasher for LED turn signals. Look around and you should be able to find one as they are fairly common. The other option is to use a resistor in parallel with the signals to draw more current and operate a standard flasher..
  • pgiinc
Posted December 27, 2006 - 08:24 AM
they have it a bajadesigns
I just got mine working same thing
  • dedminst
Posted December 27, 2006 - 02:51 PM
Thanks guys! I'll let you know happens in a couple of days.
  • Jeff@TheQuadShop
Posted December 27, 2006 - 05:01 PM
They can be bought at most good auto parts stores they are called an electric flasher.
  • dedminst
Posted December 28, 2006 - 12:57 PM
Well, I just got back from Baja Designs after purchasing their LED flasher unit, and promptly installed it. The lights do indeed flash now, BUT, they all flash at the same time! Any ideas as to what may be wrong?
  • moleculo
Posted December 28, 2006 - 01:14 PM
The turn signal indicator is causing this. It needs to be unplugged when using all LED signals.
  • Jeff@TheQuadShop
Posted December 28, 2006 - 03:15 PM
You can replace the indicator light with an LED and it will work normally.
Honda XR650L 2016
  • 0 reviews
  • 17 replies
  • 9 replies
  • 22 replies
  • Hot  29 replies
