clutch pressure plate torque on 650L?
2 replies to this topic
  • xlr8r
Posted December 22, 2006 - 11:02 AM
Hey guys, I have a 2001 650L that I'm puting back together and I can't find any torque values for the clutch pressure plate bolts in the manual. I found a general torque value for 10mm bolts (which they are) of 25 ft lbs. That seems a bit high to me since there are springs involved. Anyone know? Is there a general torque rule for all clutch bolts?
Thanks for the help!
  • cleonard
Posted December 22, 2006 - 11:38 AM
The general torque value is based on the size of the threaded part of the bolt, not the head of the bolt. The 10mm hex head bolts on the clutch are actually 6mm bolts. They will strip long before 25 ft-lbs. I think that the spec for 6mm bolts in aluminum is 9 ft-lbs.
  • xlr8r
Posted December 22, 2006 - 07:22 PM
Yup, that sounds right. I knew it was a dumb question as I typed it. Thanks for the answer!
