P-38.....ANY GOOD ??
6 replies to this topic
  • Alain
Posted January 02, 2002 - 09:56 AM
to anybody who has used one....
Does it make a noticable difference?
Is it worth the money?
  • James_Dean
Posted January 02, 2002 - 10:37 PM
Depends on your pocketbook and time. You still need to adjust the carb to offset the reduced squirt time from the accelerator pump. Usually a clip position richer, then it produces a consistently stronger power delivery through mid-throttle. If you don't adjust, the P-38 does little to nothing for you other than save gas.
The same thing can be done nearly for free with one of a few creative solutions. Since your bike is a 98/99, Taffy suggested using a small block-connector on the pump rod to limit the stroke, easy to adjust. Kevin posted about mounting a bolt thru the bottom of the pump cover too, washers or a nut will adjust the depth.
See the "KL Mod" posting.
The '00 and new bikes have the BK Mod.
  • Alain
Posted January 03, 2002 - 02:26 AM
Thanks for the info
  • Joel_Gibson
Posted January 07, 2002 - 12:55 PM
James Dean
Thanks for the input. I had a P-38 delivered the other day. I havent had time to put it on yet. Did you experience any problems by going richer one clip? Are there any other tricks to making this mod worth while?
  • James_Dean
Posted January 07, 2002 - 03:07 PM
The other suggestion is to get a carb needle from either the YZ426 or YZ250F. Optional needle OBELN (P/N 5NL-14916-EN) works great and adds more mid-range. Try clip #4.
OBELN, EKN, and EJN have no difference other than clip position. (ELN#4=EKN#3.5=EJN#3)
[ January 07, 2002: Message edited by: James Dean ]
  • DPW
Posted January 07, 2002 - 03:42 PM
A little research and I found the answer to my question I had posted.
[ January 07, 2002: Message edited by: DPW ]
  • Jekel
Posted January 07, 2002 - 04:08 PM
i have the P38 installed, another great mod is the TY-Davis throttle wheel. I didn't realize how my throttle cables had been frayed until I changed wheels.
