need a rear wheel
9 replies to this topic
  • jevc
Posted December 22, 2006 - 09:01 AM
I need a rear wheel for a 426. the bearings went out and ruined the hub. I cant understand why it happened so fast. I just checked the bearings a couple weeks ago and all looked good. then on one ride the bearings went and took the spacer and the hub with it. Anyway, the rim is a bit bent and might as well replace that when I get a new hub. anybody got a good used one they arent using?
  • NavyNuke
Posted December 22, 2006 - 07:31 PM
nope sorry, but any yamaha 99-06 has the same hub at least the YZ and WRs do. even the 2 strokes.
  • Luigic81
Posted October 10, 2007 - 11:29 AM
I have a '04 WR450 and I want an extra rim to mount a street tire and or sand tire for quick changes. Will any 18inch rim fit? For example on ebay there is a bunch of 18inch rims from really old yamahas or even other makes..... Or does it have to be specific to my bike? Also does anyone have one to sell me??
  • Birdy426
Posted October 10, 2007 - 09:31 PM
Check e-bay. I saw a cople on there tonight
  • Luigic81
Posted October 10, 2007 - 10:02 PM
Yea I saw those also, but i wasn't sure which ones would fit my bike....
Will any 18 inch rim fit? One of the ones on ebay was off a 1975 yamaha...
  • JMathis
Posted October 14, 2007 - 04:00 PM
I have a 19 inch rim that works on the wr's and I would be willing to part with it. I had intended on putting more street friendly tires on the 18 inch and running the 19 inch when I was off roading. That turned into more trouble than it was worth. Make me an offer if you are still looking.
  • Luigic81
Posted October 15, 2007 - 06:55 AM
I currently have an 18inch rear that I use for off roading, Would it make more sense to use the 19 for offroad and the 18 for street? Also do they make 18inch street tires? I know my gixxer runs 17.5's ...? Thanks, also what price range are we looking at for the rim? and do you have an extra front?
  • JMathis
Posted October 15, 2007 - 05:22 PM
You can get 18 inch dual sport tires but I do not know about true road tires. I do have the matching front rim as well. I never got it to work on my WR since it was off a YZ it does not have the correct spacer since the WR uses the speedo gear. All I needed to do was to go get the spacer that the YZ uses but I just never got around to it. As far as a price goes, I don't know make me an acceptable offer for the both if you need them. I did not notice a difference between the 18 and 19 but I am sure there is someone on here that will say there is a difference that you would feel.
  • Luigic81
Posted October 15, 2007 - 09:06 PM
So is the problem with the front wheel fitting due to the odometer, cuz I disconnected that cable? Or would I still need a spacer? What size is the front a 21 inch?
  • JMathis
Posted October 16, 2007 - 05:22 PM
Yes, you would still need a spacer. I have my speedo disconnected as well but since the YZ wheel does not have a speedo it requires a spacer in it's place. Yes the front wheel is a 21 inch.
