Blue smoke when cold
5 replies to this topic
  • YZ426F Rider
Posted December 21, 2006 - 09:17 AM
My '02 426 has just started blowing a little bit of blue smoke after I start it. It only blows the smoke when I blip the throttle but not when it is at idle. The bike runs great and once the bike warms up it disappears. The bike does not use oil that I can tell, but then again I change it about every 8 hrs.
Valve guides/seals? If it were the rings then it would smoke all the time wouldn't it?
  • 642MX
Posted December 21, 2006 - 10:19 AM
Have you ever been in the motor?
  • YZ426F Rider
Posted December 21, 2006 - 10:33 AM
Not other than to replace the exhaust cam and check valve clearance. Bought the bike bike used so I don't know how many hours are on it.
  • 642MX
Posted December 21, 2006 - 10:36 AM
Its probably a valve seal, the valve guides typically never wear. And its definitely time to replace the rings, cam chain, valve springs & valve seals.
  • YZ426F Rider
Posted December 21, 2006 - 10:52 AM
I was planning on doing the timing chain this winter. Never replaced valve components before...is it rocket science or no?
  • 642MX
Posted December 21, 2006 - 12:04 PM
Its not rocket science. You will, however, need a valve spring compressor. You can remove the valve seals with a pick, and reinstall them with your fingers.
  • Hot  47 replies
  • Hot  38 replies
  • On January 15, 2017
  • Hot  30 replies
