new exhaust
7 replies to this topic
  • thrtljunky
Posted December 20, 2006 - 10:38 PM
hey i just put a new fmf on the 426 but was made for the 450....fits perfect but notice more backfire on deceleration..is this the pipe or a possible valve needing adjustment????
  • Kyle Prior
Posted December 20, 2006 - 10:40 PM
The pipe could be a little loose, leaking exhaust. This is likely the cause if it didnt happen before.
  • Smokeslider
Posted December 20, 2006 - 11:52 PM
Did you rejett for the pipe? Pop on decel after putting on a new pipe sounds like a lean condition. When you upgrade your airflow, you'll need to jet richer to make up for it.
  • ____Kurt____
Posted December 21, 2006 - 12:06 AM
run it lean and fry the motor:banghead:
Posted December 21, 2006 - 08:19 AM
:thumbsup: Check the header gasket and the mid pipe joint.
  • thrtljunky
Posted December 21, 2006 - 04:26 PM
did not re-jet....header gasket and joint are sealed.....jet is stock what should i try for new jet??
  • MRD RACING
Posted December 21, 2006 - 07:19 PM
this can normally be cured by ritchening the pilot screw, if it does not stop popping on decel by the time you are at 3 turns out you will need a bigger pilot jet
  • 800xr
Posted December 22, 2006 - 07:43 AM
I installed a white bro's carbon pro on my 06 and it popped like that. I raised the needle two clicks and installed bigger main. Problem fixed.
  • Hot  47 replies
  • Hot  38 replies
  • Hot  28 replies
