Getting the damned seat off
10 replies to this topic
  • pjpoo
Posted December 19, 2006 - 08:28 PM
I'm new to the XR650.
I can't figure out how to get the damned seat off for access to wiring/top of the air box. I spent 20 minutes trying. I pulled the front portion up and heard something pop. I don't know if it was a good pop or a bad pop, hahah.... :thumbsup:
What a wimp I must be! ARGH!
Anyway, pointers?
Any free manual online available for download?
EDIT: I found a XR650R manual. I see two bolts shown towards the rear. I found two bolts on my seat and removed them and the seat didn't seem to budge after that... :devil:
I'll try some more and then come back to check...
  • chpxr
Posted December 19, 2006 - 08:36 PM
ok there's 2 bolts under the seat facing outwards take those out lift the back up then slide the front of the seat down and back and it should come right off
  • pjpoo
Posted December 19, 2006 - 08:38 PM
I'll see what's up. For some reason two bolts on the outside of the subframe were not immediately apparent...
  • chpxr
Posted December 19, 2006 - 08:50 PM
glad you got it worked out:ride:
  • pjpoo
Posted December 19, 2006 - 09:29 PM
Yeah, it was the two bolts on the under/inside of the subframe. For whatever reason the first time I undid those I didn't get the seat to budge...
  • frankstr
Posted December 20, 2006 - 06:30 AM
Glad you figured it out, pjpoo....Welcome to Thumpertalk....
:thumbsup: :devil:
  • needsprayer
Posted December 20, 2006 - 06:51 AM
Warning: Always wear a boot when kickstarting the BRP. That girl can slap you silly.
:thumbsup:
  • pburke
Posted December 20, 2006 - 07:32 AM
anyone ever see a conversion to some sort of quick release for those two bolts back there? I think it's a real PITA to get those out each time you need to get to the fuse or take the tank off for whatever.
  • pjpoo
Posted December 20, 2006 - 08:12 AM
:thumbsup:
I learned that the hard way when kick starting my '88 XR250R, which was my first dirtbike. The 650 is the L, though, so no kickstart. You can see I'm having starting troubles here in this thread: http://www.thumperta...ad.php?t=448685
  • Maladjusted_XR
Posted December 20, 2006 - 10:34 AM
Try "quick-release SS anchor pins". McMaster-Carr carries them. Kind of pricey.
  • rebelventurer
Posted December 20, 2006 - 12:54 PM
You can make the quick releases yourself with a couple of 6mm studs, a drill bit, a couple of washers, and spring clips.
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
  • 4 replies
  • 3 replies
  • Hot  35 replies
