Battery recomendations
4 replies to this topic
  • MN_Paul
Posted December 19, 2006 - 08:11 PM
My WR needs a new battery and was wondering if there is any preferred ones. The reason I am asking is that there is one for sale on ebay (new for $25) that is a sealed non gel type (made by Yusa). Since the battery is on its side, does it need to be a gel type or just a sealed unit?
Thanks,
Paul
  • NavyNuke
Posted December 19, 2006 - 09:27 PM
interstate sells the OEM Yusa one for less than any catalog. just an FYI
  • Indy_WR450
Posted December 20, 2006 - 05:02 AM
You cant beat the stock Yuasa. Get a tender while you are at it and your battery will last. I just replaced my original battery after 4 years because it was time, but it still works good and holds 12.9 volts. The new battery holds 13.2 volts. $72.00 is about the best price out there for our batteries.:thumbsup:
  • handlebar
Posted December 20, 2006 - 03:58 PM
Thanks,
Paul
If you want to save a pound or two.You can purchase a 4 or 5 amp sealed lead acid from a online battery shop or most car part dealers.They are around $40.They will not spin the motor as long as the stock battery but plenty long enough for me to get it started especially when warm.It is working good for me.
  • farkawi
Posted December 20, 2006 - 06:13 PM
Indy is right on here. The Stock Yuasa is a quality piece. Cheap batteries are just that. Cheap. A properly serviced and maintained stock battery will last for years.
