what kind of oil in steering damper?
3 replies to this topic
  • s.c.rider
Posted January 01, 2002 - 12:57 PM
What kind of oil do I put in my Scott's damper?
I loosened the slow screw too much and then turned the bars and all of the oil shot out of it. someone said i could use ATF but I don't know.
Any help is really appreciated.
  • rwcfrank
Posted January 01, 2002 - 01:05 PM
A light hydraulic fluid should be fine.. I would try hydraulic jack oil, its a light viscosity(sp)hydraulic oil...
  • mcarp
Posted January 01, 2002 - 02:43 PM
According to the scotts manual, 2.5 wt suspension fluid or scotts damper fluid. The Scotts fluid has a nice bottle with a tip that fits into the fill holes perfectly.
If you go with something other than Scotts, try to find a syringe to inject the fluid. Much easier, I promise. Your vetwill have ones that fit perfectly, too.
Are you going to change the fluid as well?
  • MX_Tuner
Posted January 01, 2002 - 03:59 PM
I use Spectro 125/150 suspension fluid for Scotts dampers. This is as close as I have come to the stock Scotts fluid damping characteristics.
