Front fork rebound dubing clicks
1 reply to this topic
  • zar
Posted December 17, 2006 - 11:25 PM
I changed front fork oil on my WR450-F 05' and i noticed that the right fork has 30clicks of rebound bubing adjustment instead of 20!
Does any one knows what might cause this?
Thanks
  • handlebar
Posted December 18, 2006 - 07:20 AM
You did not screw the lock nut down on the damper shaft all the way before you reinstalled the cap. If you do it correct you should be able to spin the cap on by hand until it bottoms AND see a small gap between the locknut and cap.Also...back the adjustment screw ALL the way out before you install the cap.:thumbsup:
