  • Instagram
Related Reviews
Yamaha YZ450F 2003
Last review by Garrett Canada
Yamaha YZ450F 2012
Last review by Jason Heinrich
Yamaha YZ450F 2005
Last review by 2fast4luv
Yamaha YZ450F 2014
Last review by Gode
Last review by Tommyk_55
Related Garage
Yamaha YZ450F (2016)
Owner: 1973 Honda XR75
Added on January 10, 2017
Common Threads: Look here 1st! Mods, Maintenance, Common Issues and FAQ's
  • This topic is locked This topic is locked
1 reply to this topic
Posted December 17, 2006 - 08:03 PM
Important: These threads are for reference and quicker access to commonly discussed issues only. They DO NOT replace the service manual or common sense, and not every contribution is necessarily 100% accurate! Whenever you consider doing one of the modifications here, I strongly suggest you read and evaluate all of the available info and consider carefully the up and downside, what it is intended to accomplish, the reversibility in case you don't like it, whether it is applicable to your bike, and any possible consequences. All of them have been successfully used by somebody, but I cannot vouch for each and every one. Thumper Talk itself endorses none of this information.
Note: Many of these threads are such that they need to stay on topic to be useful. Please be sure that any post you put up in one of these threads bears as closely as possible on the topic of the thread. For example, don't post questions about another members jetting in the jetting database. Post the jetting you use, and ask your questions in a new thread, or by PM. In a thread that focuses on one particular bike, try not to ask questions about a different model. Off topic posts are always subject to being weeded out.
Thanks,
Submit threads for addition to this list here -http://www.thumperta...ad.php?t=444209
Report errors or broken links to me by PM, please.
Part One: Engine, Transmission, and Fuel System
Engine
The Decompression Cam Mod (DCM) (for 400/426's Only) (This info does not apply to YZ/WR250F models)
Link to Instructions:
http://www.thumperta...078#post3706078
Clarification of "DCM" Timing Instructions
http://www.thumperta...040#post5378040
The whole, original 450 DCM Thread:
http://www.thumperta...ead.php?t=60381
Oil Change Procedure:
Valve Clearance Check/Adjustment
http://motoman393.th...ech/valves.html
Oil Leak at Right Front of Engine, or
Right Radiator Appears to Leak (Smoke from Radiator and Exhaust), or
Unexplained Open Hole in Front of Head.
http://www.thumperta...419#post1522419
Cam Chain Replacement
http://www.thumperta...405#post3150405
Timing Cams: How Many Pins Between Cams?
http://www.thumperta...845#post7467845
Lapping Valves? Cutting Seats?
http://www.wiseco.co...alveInstall.pdf
Breather Tube Re-route:
Discussion
http://www.thumperta...651#post4054651
A Clean, Simple Solution
http://www.thumperta...ad.php?t=706602
A Different Breather kit parts list
http://www.thumperta...573#post4956573
The Fabulous Glowing Red Header
http://www.thumperta...ad.php?t=236304
Engine makes noise
http://www.thumperta...131#post5345131
Dry Sump Oiling Systems
http://www.thumperta...903#post5221903
Paper vs. Mesh Oil Filters
http://www.thumperta...297#post4676297
Lower Oil Filter Cover Bolt Stripped
http://www.thumperta...ad.php?t=575367
Prevent Thread Damage to the Lower Filter Cover Bolt
http://www.thumperta...ad.php?t=634724
Engine sometimes very hard to turn over, no Auto Decompression, or feels locked up after stalling:
http://www.thumperta...763#post9110763
How Auto Decompression Works in a YZF:
http://www.thumperta...171#post6849171
Honing Nikasil Plated Cylinders
http://www.thumperta...759#post4380759
Water Pump Seal and Shaft Replacement
http://www.thumperta...ad.php?t=940018
Repeat failures of water pump seals, especially in '06 and later models:
http://www.thumperta...ad.php?t=785425
Cylinder Head Torque: What's with the Angles?
http://www.thumperta...ad.php?t=972816
Transmission
Noise at Idle; Stops When Clutch is Pulled
http://www.thumperta...282#post5362282
'06 YZ450F: Hard Shifting, Inaccurate Shifting, Jumps Out of Gear
http://www.thumperta...391#post4922391
The '01 Clutch Mod for the 2000 YZ426
http://www.thumperta...ad.php?t=461631
'07-'09 (possibly later models) Clutch gains free play when hot, slips
(Conversion to '06 clutch)
http://www.thumperta...940#post7261940
WR450 5 speed swap for 4 speed YZ450's
http://www.thumperta...046#post2761046
Wide Ratio Transmission for the '06 -'09 YZ450F
http://www.thumperta...ad.php?t=464212
Hybrid (or full WR) Wide Ratio Trans for 2010-2013 YZ450F
http://www.thumperta...on-a-10-yz450f/
Fuel System
Electronic Fuel Injection
Yamaha EFI Tuner Manual:
http://www.mcnews.co...uner_Manual.pdf
2010 YZ450 Fuel and Timing Maps Used by TT Members
http://www.thumperta...ad.php?t=860507
How to clean the fuel filter on EFI YZ450's
http://www.thumperta.../#entry10702600
Carburetors
FAQ: Where is the Idle Mixture Screw?
http://www.thumperta...ad.php?t=696672:
How to confirm your pilot circuit setting-
http://www.thumperta...ad.php?t=327405
Jetting Used by other Members: (Add only the info about the jetting you use. If you have a question or a comment, please post to a new thread)
http://www.thumperta...ad.php?t=694921
Cleaning Carb Jets and Passageways:
http://www.thumperta...726#post8021726
A Simple Guide to Jetting by the Seat of your Pants:
http://www.thumperta...699#post2881699
Changing Late YZ450 Pilot Jets Without Moving the Carb
http://www.thumperta...ad.php?t=556427
Exhaust Backfire on Deceleration
http://www.thumperta...599#post3710599
http://www.thumperta...613#post3350613
Every Thing (just the title,its not really everything) You Need To Know About Carbs-
http://www.thumperta...ad.php?t=404426
Info on the Zip-Ty Carb Mod
http://www.thumperta...ad.php?t=458476
The O-Ring Mod How-To
http://www.thumperta...233#post6157233
What a Leak Jet Really Does
http://www.thumperta...330#post4415330
http://www.thumperta...966#post6081966
http://www.thumperta...344#post6091344
Alternate Accelerator Pump Diaphragms and Leak Jet Info
http://m.bobbitt.hom...fm/tech/ap1.jpg
http://m.bobbitt.hom...fm/tech/ap2.jpg
http://m.bobbitt.hom...fm/tech/ap3.jpg
1/4 Turn Throttle Mod
http://www.thumperta...ad.php?t=485653
The BK Mod (accelerator pump mod for YZ426)
http://motoman393.th.../tech/carb.html
The "Taffy Mod" for YZ400 models
http://docta-zaius.f.../whats_new.html (Watch for pop-ups)
Replacing YZ400 carbs with newer units
http://www.thumperta.../#entry11011329
High Octane Fuels
http://www.thumperta...893#post2827893
http://www.thumperta...255#post2920255
Posted February 20, 2009 - 10:24 PM
Part Two: Chassis, Electrical, and Miscellaneous
Chassis
How to repack swing arm/linkage bearings
http://www.thumperfaq.com/swingarm.htm
Greasing steering stem bearings how-to
http://motocross.tra...-steering-stem/
Updated '06-'08 Upper Steering Head Bearing to Prevent Water Contamination
http://www.thumperta...710#post6702710
How to Stop Chain Sliders from Wearing the Swing Arm:
Grayracer513's Method:http://www.thumperta...r-to-swing-arm/
Motoman393's Method:http://motoman393.th...h/swingarm.html
Chain Seems Too Loose When Adjusted to Specified Tension:
http://www.thumperta...182#post8906182
Chain Hits Frame, Rear Wheel Alignment:
http://www.thumperta...955#post4244955
http://www.thumperta...ad.php?t=548940
Basic suspension tuning tips-
Set your Race Sag
Use Sag to Check the Spring Rate
Basic Suspension Setup Guide
How to Bleed Twin Chamber KYB Fork Cartridges ('05 and later YZ/YZF)
http://www.thumperta...814#post8762814
Base Bolt/Jam Nut Clearance: Gap or No Gap? Clarification to the Service Manual Regarding Fork Damper Rod Jam Nuts ('05 and later YZ/YZF)
http://www.thumperta...008#post8002008
Fork Damper Cartridge Free Piston Mod to prevent Failure of the Piston and Improve Plushness
Mod:
http://www.smartperf.../YZMODASSEM.htm
Piston Failure:
http://www.thumperta...ad.php?t=650136
Wheel Interchange Information for YZF models
http://www.thumperta...ad.php?t=632582
'08 Front Brake Locks Up After Lever Replacement
http://www.thumperta...853#post5844853
Tire Change How-to (video link)
http://motocross.tra...ip-tire-change/
Lacing and Truing Spoked Wheels
http://www.thumperta...ad.php?t=583471
Electrical
Late YZ450 Street Grade Lighting System How-To
http://www.thumperta...ad.php?t=622555
Late YZ450 Baja Grade Lighting How to: (It's expensive!)
http://www.thumperta...ad.php?t=696590
Using a WR426 stator on a YZ426 (aka "Pink Wire Mod" or "floating the ground")
http://www.thumperta...52#post10674552
Misc
Owners Manuals
http://www.yamaha-mo...uals/index.aspx Printable
http://www.yamahaown...ook.com.au/?r=0 Mostly non-printable
YZF or WR450? How to decide?
http://www.thumperta...235#post8107235
450 Plastics Conversion on a 426
http://www.thumperta...ad.php?t=151436
DIY Carbon Fiber Parts How-To:
http://www.webbikewo...torcycle-parts/
How to Start a YZ426 (Video with Doug Dubach- Special Thanks to Yamaha Motors, and all the Good People at Dubach Racing Development)
(Requires QuickTime, or a player that will handle QT videos)
Part 1: (Cold Start) http://www.yamaha-mo...troke_vid_a.mpg
Part 2: (Hot Start) http://www.yamaha-mo...troke_vid_b.mpg
Note: Video may take a few minutes to download.
  • Hot  113 replies
  • 10 replies
  • 9 replies
