Swingarm/Steering stem grease questions...
8 replies to this topic
  • wickedsprint
Posted December 15, 2006 - 01:08 PM
I want to tear down the BRP this winter and totally grease all of the above, probably a stupid question but is there a specific type grease that is reccomended for the suspension parts? From what I have been reading it seems I can do most of the swingarm greasing without dealing withthe special honda tools that go for 90 bucks.
  • cleonard
Posted December 15, 2006 - 02:39 PM
Take a look at the Honda manual for a type. Sometimes the suggest the moly paste that is available at a Honda dealer.
Usually it really doesn't matter as to the exact type. Waterproof is a good idea, an I either use that or a moly type grease, or even the moly paste.
  • Barro
Posted December 15, 2006 - 04:00 PM
I use Aluminum moly grease because of the linkage is often in water,
Go to www.mcmaster.com, in page 2022 there is a blurb on greases. After reading it my first choice was part number 1208K22 (the one I use) and a second choice would have been 1372K16.
Choose the one you like. McMacster has a good selection in stock.
Eduardo.
  • creeky
Posted December 15, 2006 - 04:08 PM
I am not a big fan of Bel-Ray products, BUT...they market a very good waterproof grease. CRC also sells an excellent waterproof grease.
  • pigryder
Posted December 15, 2006 - 05:05 PM
here's what I use, a 50/50 mixture of high temp wheel bearing grease and anti-seize. Just mix it real good, the anit-seize helps to displace water. Ive used this on my R for 3 years and have never replace and bearings or spacers and yes I put miles on this thing :thumbsup:
  • XR4DEZ
Posted December 15, 2006 - 05:40 PM
The swingarm bolt will tap out when you remove the nut(use a socket extension), you don't have to fool with the locknut on the brake pedal side. Remember the bearings are needle type, so push the bushings out only far enough to allow greasing and still keep the bearings in place. Hope this helps.
  • jbird710
Posted December 15, 2006 - 10:20 PM
+1 for Bel-Ray. Use it on all of my CR500's and XR400. I haven't done the 650L or 650R; but both are due and will be done soon.
http://www.belray.co...rtbike&q=grease
  • wickedsprint
Posted December 16, 2006 - 07:23 AM
Thanks guys, this is going to be my winter project, as well as scoring some new rims for it as I bent the front one pretty nicely on a friggin rock. If I am not completely removing the swingarm what is the easiest way to get all of the old bad grease out?
  • motopsycho650
Posted December 16, 2006 - 07:55 AM
Bel-ray water-proof grease. I use it to seal my air filter as well. I don't use any other Bel-ray products, but the water-proof grease is great stuff.
  • Hot  29 replies
  • 9 replies
  • Hot  35 replies
  • 3 replies
  • 22 replies
