04 450f problem
9 replies to this topic
  • Blank Stare
Posted December 13, 2006 - 11:09 AM
I would do a search, but i don't know what this part is. I cant find it in the service manual that came with the bike either? On the head where the xhaust mounts up, directly above that There is a hole that i think use to have some sorta plug in it. There is noting there now and so oil came out of the hole. I found one picture in the manual section 4-82 that shows a bolt or plug there. What is it called and why is it not anywhere in the service manual. :thumbsup: HEEELLLLLPPPPPP
  • motobeck
Posted December 13, 2006 - 11:24 AM
Sounds like the hole where they used to run the decompression mech. Check in the TT store for Decompression Plug. Hope this helps.
  • Blank Stare
Posted December 13, 2006 - 11:28 AM
I was thinking that. I saw that TT has some special plug that is made not to blow out. but when i was reading the part description it was talking about a cam swap. I'll go back and check it out. What kinda of problem can occure from this plug blowing out? I think i caught it right after it happened.
  • Blank Stare
Posted December 13, 2006 - 11:31 AM
Ok went back and reread the part description. looks like it is it!
  • motobeck
Posted December 13, 2006 - 11:33 AM
Cool, that should solve your problems.
  • flintlock28
Posted December 13, 2006 - 04:39 PM
The hole was there back when Yamaha used the manual decompression lever. When they went to auto-decompression, they didn't want to spend the money to re-tool the head (expensive), so they installed a rubber plug.
Sometimes it comes out, and that's what happened to you....order the new Aftermarket one from TT, and your problems are gone.
Posted December 13, 2006 - 04:55 PM
Their actual reason for this was to allow retrofitting manual decompression, and they offered a complete kit to accomplish that.
They designed it out of the '06 head, since almost no one wanted to add the kit.
  • flintlock28
Posted December 13, 2006 - 05:03 PM
Oops, my bad....Grayracer is correct. I wrote that with my three year old and 4 month old crying, and had a Brain fart.
  • Blank Stare
Posted December 13, 2006 - 05:17 PM
i thought i already had that. the lever above the clutch lever
Posted December 13, 2006 - 07:15 PM
It's time for you to brush up on your bike a bit. That's the hot start lever.
  • 10 replies
  • 0 replies
  • Hot  36 replies
  • Hot  30 replies
