MSR Raptor on 05 WR
6 replies to this topic
  • nevadaoutlaw
Posted December 13, 2006 - 10:46 AM
I was going to purchase a MSR Pro-Raptor clutch lever assembly w/ hotstart for my 05 WR450F.
Does it bolt right on? I don't want to modify much.
Also, I know the clutch switch cable will not work with this, mine fell out a month ago and I didnt even know what is was for.
What do I do with this cluthc switch cable? I saw a post that I connect the two wires together, or do I just disconnect, or do I need it?
Thanks....
I just need an easier clutch pull. I am doing these long 5 hour races and my arm can't take it.
  • Asgeir
Posted December 13, 2006 - 11:04 AM
Leave the switch hanging, it will not hurt...or connect those 2 wires together if you do not like the switch in the loom.
  • Asgeir
Posted December 13, 2006 - 12:57 PM
MSR 34-2002 is a clutch perch with hot start and a hole for the clutch switch.
You can find it here :
http://shop.thumpert...t.asp?p=443&s=2
Then you need the MSR 34-1984 shorty lever :
http://shop.thumpert...t.asp?p=442&s=2
This should fit the 03-06 WR450F
  • Fullbore4
Posted December 13, 2006 - 01:05 PM
Thanks Asgeir.........those are about half the price of yamaha replacements!!
  • Derwud
Posted December 13, 2006 - 03:32 PM
I ran the MSR Raptor on my YZ for years and loved it. Switched to ASV, a little better.
  • Asgeir
Posted December 14, 2006 - 01:40 PM
Do you have the same light feel you can get with the MSR ? (by 3 different holes for the cable in the lever)
  • Derwud
Posted December 14, 2006 - 03:02 PM
THe ASV's were almost as light in pull, but the lever seemed much smother and better built.
