velcro seal savers
14 replies to this topic
  • pudadin
Posted December 12, 2006 - 06:47 PM
Hi Gang,
Has anyone tried the seal savers that have velcro straps...ie easier to insatall and clean? If so, who makes them?
Thanks
  • JRozman
Posted December 12, 2006 - 07:09 PM
http://www.krewmx.com/equipment.htm
  • boer
Posted December 12, 2006 - 08:32 PM
anybody using these?
http://shop.thumpert...fault.asp?p=852
  • Humunn
Posted December 12, 2006 - 09:02 PM
Hi Gang,
Thanks
I had used the velcro strap seal savers from White Bros before they discontinued them. They work great!
  • tony1970
Posted December 12, 2006 - 09:13 PM
I have been running these for over and year and I love 'em!:thumbsup:
  • baha
Posted December 12, 2006 - 11:22 PM
I bought the long tusk one's that cover the entire fork tube. You have to take off the tire to put them on but they give great protection.
  • jbrooks26
Posted December 13, 2006 - 02:09 AM
I have a set of these and I will be going with the Shock Sox next time from the other site linked to in this thread. The Fork Skins work well, but in my opinion are a little flimsy and hard to install. Just my 2c, for what it is worth.
Josh
  • mxchamps
Posted December 13, 2006 - 09:43 AM
The Tusk ones work great. I have had them since February. They are easy to clean, just roll them over when you are washing your bike and give them a quick spray. They only cost me 10 bucks too. Can't beat that.
http://www.rockymoun...94&navType=type
  • pudadin
Posted December 13, 2006 - 12:45 PM
thanks! Bought today!!! Nice stocking stuffer!
  • Summit
Posted December 13, 2006 - 01:52 PM
Which ones, short or long? And what size (mm) for WR450?
  • mxchamps
Posted December 14, 2006 - 03:31 PM
The long ones cover the outer fork tube all the up to the lower triple clamp to protect against roost. I run the short ones myself (like the look better). You will want the largest size. Your inner fork tubes are either 46mm or 48mm.
  • jerryls
Posted December 14, 2006 - 08:53 PM
Buy the long one, cut it in half, and you'll have two pairs of short ones. That's a great deal for $12.
Jerry
  • crooks420
Posted December 15, 2006 - 06:58 PM
I bought my Seal Savers on Ebay for about $12, and they work great. It is nice to be able to take them off when washing the bike.... alot of fine dust will collect at the edges, so that gets washed too.
I got these after a $300+ dealer rebuild :thumbsup:
Jesse
  • mxchamps
Posted December 21, 2006 - 09:26 AM
I got these after a $300+ dealer rebuild :devil:
Jesse
You get hosed by the dealer when it comes to changing fork seals. I bought a Tusk seal driver for $39 and it has been worth it's weight in gold. Now my buddies pay me to change their seals.:thumbsup:
  • handlebar
Posted December 21, 2006 - 06:33 PM
Seal savers will damage the plating on you fork legs over time if they are not keeped VERY clean.The dirt embeeded into the saver will act like fine sandpaper.Most of the time seal leaks can be fixed by the film trick.Savers work by keeping dirt from the seals.The film trick works by removing that dirt.When a seal leaks it is almost always a small peice of dirt that holds the lip of the seal off the tube and allows oil to bypass.Remove the dirt and fix the leak WITHOUT relacing the seal.:thumbsup:
