Elec Starter Wiring Diagram ?
2 replies to this topic
  • tvrjohn
Posted December 12, 2006 - 04:39 PM
Hi guys
Having some trouble with WR450 04
When i push the ignition switch in, starter motor turns !
Have disconnected starter button, makes no difference
Had to pull a fuse in starter relay so i could run the engine via kick starter
Changed relay unit next to battery and it makes no difference
Can't see any wires damaged / touching / shorting out
Wiring diagram in online manual here has no colour coding
think this would help, if info is avaliable
Any suggestions,
Help please
  • Asgeir
Posted December 13, 2006 - 11:28 AM
I think this applies to the WR450F
Electrical diagram of a WR250F :
There is this diode that you should check #5
There seem to be 2 relays one # 9 and one close to the starter #12
If removing the relay stops the continius starting and it is not the start button then probably it is a wire that is Blue/Black is shorted to ground.
I can e-mail you better drawings if you PM me your e-mail address.
  • tvrjohn
Posted December 14, 2006 - 02:37 AM
thanks for that info, however i have sent you a PM for clearer info
Thanks, John
