Finding the Grey wire On 2007 WR's
4 replies to this topic
  • joshbeene
Posted December 12, 2006 - 09:30 AM
The first time I went to cut the grey wire I accidientally cut the black wire on the 6-pin because I thought there was only one 6-pin connection. It turns out there are two seperate 6-pin connections and only one has the grey wire. The one with the grey wire may be hiding next to the CDI box, behind a white plastic bracket.
That connection is kinda hiding and I didn't wan't people to get frustrated so I wrote this thread for everyone with a new 07 WR.
  • WR450_Mike
Posted December 12, 2006 - 09:41 AM
Correct. But, why cut it when you can just remove it from the connector and stow it. That way, it is easily re-connected if for some reason you wanted to.
  • bake5
Posted August 07, 2007 - 03:31 PM
Where Is It?
  • KennyMc
Posted August 07, 2007 - 04:31 PM
It's behind the side panel on the left side (shifter).
  • Mike1977
Posted August 07, 2007 - 09:38 PM
What is the advantage of cutting the grey wire?
