XR650L Rear Spring Change
4 replies to this topic
  • dukeryder
Posted December 12, 2006 - 12:24 AM
I searched and every thread says no special tool required or are vague. But that lock ring is on there pretty good and I can't even loosen it by hitting with a punch and hammer.
Do I need a special wrench to take that lock ring off????
I did the fork springs no problem, and figured the rear shock spring woulda been easier.
  • tirebiter
Posted December 12, 2006 - 05:07 AM
There should be two lock rings. Loosen the one furthest from the spring first.
It can be a bitch if the spring's never been broke free before.
Keep at it, it'll free up.:thumbsup:
  • rebelventurer
Posted December 12, 2006 - 04:06 PM
A little penetrating lube wont hurt either, and yep you gotta get the top one moving first!
  • dukeryder
Posted December 12, 2006 - 05:44 PM
Yeah I was definetly trying to loosen the top ring.
I was using a punch and a ballpeen hammer to try and loosen it but it didn't budge. I'll dump somre liquid Wrench on it.
I thought there might be some Honda specific tool that I needed. Those Riceboy Cars with Coilovers have a huge wrench that hooks into those little indentations that they can loosen those rings with to adjust ride height. I thought I might need to get one of those but it looks like you guys don't use any special tools.
  • tirebiter
Posted December 12, 2006 - 06:34 PM
One time I tried to "unload" the spring by latching on to a couple of coils with a pair of visegrips, thought it should make bustin' the lock rings easier..bad idea. :devil:
I managed to squeeze the spring down alright, started hammering away at the rings, but when the visegrips decided to let loose.. wellll...
Fingernail's just about grown back now..:thumbsup:
  • Hot  60 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 17 replies
  • 9 replies
  • 22 replies
