Help- front fork oil!
7 replies to this topic
  • zar
Posted December 11, 2006 - 09:42 PM
Does any one knows the recomended SAE size fork oil for the WR 450F 05'?
  • Big Tim
Posted December 11, 2006 - 11:17 PM
Not off the top of my head. But, if you go to the WR performance index (sticky topic) I think I saw "free WR manuals on PDF"
That should help you out.
Good luck
  • pjriss
Posted December 12, 2006 - 06:01 AM
SAE numbers don't mean shit when it comes to suspension oil. Read this: http://www.peterverd...om/lowspeed.htm
  • Wasabi
Posted December 12, 2006 - 06:09 AM
You will be wanting 5w oil mate. :thumbsup:
Use suspension specific oil for best results, there are heaps available.
  • bg10459
Posted December 12, 2006 - 08:47 AM
I'm using Mobil1 synthetic ATF.
  • saqu
Posted December 12, 2006 - 12:39 PM
By manual it's "01 fork oil", it corresponds to somewhere between 2.5W and 5W by MOTUL. If you can get Öhlins no. 5 oil, it's about it. Check the link
http://www.motul.com..._blendchart.pdf
Sorry here is the better one
  • SXP
Posted December 12, 2006 - 01:00 PM
Second that. The suspension action is just so......slick...is the best I can describe it as. This is especially noticeable in back-to-back comparisions between two similarly valved/adjusted bike where one has Mobil 1 ATF in it and the other (as in my test) Kayaba 01 oil. The best part is the Mobil 1 seems to maintain this slick/plush feel even after many, many hours of use. If you do switch from a suspension specific oil to the Mobil 1, you may have to adjust your clickers by one turn from your original settings.
I like it so much in the front, and as I work on my own suspension, I'm thinking of trying it out in the rear shock. I know people are going to say "too thick", but that's what I heard about using it in the front too, so we'll wait and see.
  • pjriss
Posted December 12, 2006 - 05:08 PM
Interesting and it makes sense. I would expect synthetic ATF to outlast pretty much any suspension fluid. I've always had good luck with PJ1 Cartridge Pro 3.5 but maybe next time I'll give the ATF a try.
